Main > Everything Else
Networking help needed
<< < (3/3)
Ed_McCarron:
--- Quote from: testicle187 on May 29, 2008, 04:52:50 pm ---I disagree to an extent.  I would much rather take the one minute of time it takes to crimp an end on a cable than pull an entire new cable.   For short cables it makes sense, but you would never go and buy sets of 100 ft + cables, you buy a spool.
Nah, don't pull a new cable.  When you first install the cable, terminate on a proper RJ-45 jack.  Install a wall plate.
Then, when something goes bad, odds are you just plug in a new patch cord between the wall jack and the device.
On the off chance someone puts a nail through a cable, you're pulling again anyway.
You -did- pull in a pull string the first time, right? ;)
somunny:
If the cable is bad it is the pullstring.
Ed_McCarron:
--- Quote from: somunny on May 29, 2008, 08:57:17 pm ---If the cable is bad it is the pullstring.
Good point.  Every time I've tried that in the past, it ends up being taped in a bundle.  Its gotta be a subset of Murphy's law or something.
Navigation
[0] Message Index
[*] Previous page
Go to full version
