Main > Software Forum
Dragon King Video Card Poll and Bug Report Thread
Pages: << < (2/12) > >>
Howard_Casto:
"Can't show non-modal form when modal form is displayed" bug located...
Cause:  Dx and the message box are fighting for screen space....
Temporary Solution:  Setup the masterlist ahead of time by going to your "\list generator\" folder and clicking on the exe.  When you go into Dk again your masterlist will be in place and the auto-setup will be bypassed.  You will have to go into the menu and "refresh list" to finish the list generation process.
GSXRMovistar:
I tired that Howard but I still get the "Timer1 Subscript out of range", clicking okay just closes the app down. :(
Howard_Casto:
--- Quote from: Howard_Casto on June 01, 2003, 09:09:54 pm ---When you have a problem the best thing to do is email me.  But if it's already mentioned here refer to it with the same name and/or description that's given here.
Howard_Casto:
Listinfo "input past end of file" bug found....
Cause:  You have a history.dat in your mame folder which uses a different format from the one I personally use.
Temporary Solution:  Remove your history.dat
Howard_Casto:
Ati Card Issue with rage 128 chipsets.
Symptoms:  No display and/or crashes shortly after startup.
Temporary Solution:  None at this time.  I'm working on it. :)
***Update**** As of dk 0.7 rage128 cards "almost" work.  to check it out:
in the frontend.ini
 turn on rage128
set your texformat to 0
turn on software or partial hardware modes for the render mode
Go to full version
