Main > Main Forum
Is there such a thing as a Classic MAME batch file to...?
Pages: << < (2/3) > >>
leapinlew:
--- Quote from: Turnarcades on May 26, 2008, 11:30:05 pm ---Took me about a week, with several hours a night, to remove all the games I didn't want
Takes a while, but it's worth it.
I agree with this. It's a pain, but worth it. I've had to do it several times based on the type of game being built. I have several folders with different rom sets in each. 4 way, vertical and 1 button, 4 way, vertical  and 2 button, 8 way horizontal and 6 buttons.
Factor in PC's having different processing capabilities and I still have to thin down the list.
CrazyKongFan:
If you're using MAME32, you can select a favorites in the menu, and add whatever you want to it. That way, you can keep the others, if you ever decide to use them. That's how I have mine set up. I left off most of the variants of each game I had, and put the main one in favorites. But I still have them available if I decide I want to play one.
ahofle:
You can use MCM to help remove some of the stuff like Mahjong and Quiz games:
http://www.mameworld.net/mcm/
Turnarcades:
--- Quote from: ahofle on May 27, 2008, 10:43:32 am ---You can use MCM to help remove some of the stuff like Mahjong and Quiz games:
That's the one I was thinking of. The named escaped me!
meany:
--- Quote from: CrazyKongFan on May 27, 2008, 10:07:31 am ---If you're using MAME32, you can select a favorites in the menu, and add whatever you want to it. That way, you can keep the others, if you ever decide to use them. That's how I have mine set up. I left off most of the variants of each game I had, and put the main one in favorites. But I still have them available if I decide I want to play one.
This is what I do.  Just drag and drop into the Favorite folder.  I have about 150 in the Fav's that I consider Classic.
Go to full version
