Main > Main Forum
Laptop for Cabs
Amra:
Since we are on the subject... how about this.
Certain Brand Laptops have whats called a "Docking Station". It essentially turns a laptop into a desktop, and when your ready to run, simply remove the laptop and go.
Now, incorperate that into a Cabinet. You could have a slot on the front, behind a door or something, that you open up, slide the laptop in, and poof, instant arcade. Then when you need your computer for something else, say... schoolwork. Simply remove the laptop and use normally.
It seems like a good idea... at least to me :)
TheTick:
Of course its a good idea.... but I think the issue was cost.
He already had a laptop he could use, otherwise he would have to buy a PC or the parts to build one.
If he has the dock the would make for some really quick and effortless connections. Otherwise most docking stations are around $300. There are universial ones for about $100, but I think they are missing some features like the VGA out.
I tried buying a cheap port replicator for mine this weekend on ebay, and some a** keeps outbidding me >:(
If I get it, it should match up well with the 9" monitor I won.
Acroyear:
The laptop docking station is a good idea, but I do not have one, and its not worth buying one for this laptop. One of the resions I was considering putting it in the cab was due to the fact that the case oaround the monitor is cracking.. (Never buy an NEC, peicee of s**t!)
I have an old P100 I can use, but again, the issue is networkability. WIFI sounds like a good idea, I'll have to look into it.
Didnt think of the graphics card upgade issue on the Laptop, good call.
Hmmmm... Still need to work out an answer, :)
-Acroyear
Tommy Boy:
I travel a lot on business and have to run MAME on a laptop during the week to get my fix. My opinion is that laptops generally aren't a good option if you can go with something else.
This is my third laptop that I've MAMEd with and this one is tolerable for most games but performance is somewhat sluggish on laptops -- probably because of the poor video cards that most laptops use. My current setup is a Toshiba 2.4GHz P4 with 512MB and a GeForce4 Go420 video card.
Games that use backdrops or overlays are often sluggish, and especially at 800x600 or with cropped artwork. As one example, I can't run Asteroids Deluxe at 800x600 with cropped artwork at full speed. Frame skip 2 at about 90% is the best she'll do. :-\
Lilwolf:
Don't do it unless you already have the equipment. Many notebook video cards just down right suck! Expect 1/2 the performance on a notebook then other systems.
My bosses notebook (450 and 1.7ghz) where always withing a few 100 mhz as my home machine and I can tell you there where always a HUGE difference between them.
