Main > Main Forum
Help: Hydrogen Controller
D_Harris:
I finally got it working.
Now all I need to do is figure out how to re-map the control switches.
Anyone use "CPFreedom"?
Darren Harris
Staten Island, New York.
TOK:
Fire up MAME and hit the TAB key. The first couple options should be to configure controls globally and locally.
I do a global first, then tweak games that need odd configurations one at a time.
D_Harris:
--- Quote from: TOK on May 26, 2008, 02:55:01 pm ---Fire up MAME and hit the TAB key. The first couple options should be to configure controls globally and locally.
That does nothing much.
I opened wolfmameplus-0106.
A "MAME for Dummies" site would be appreciated.(I want to be able to record and submit INP files).
Thanks.
Darren Harris
TOK:
TAB is the default key for setting options in regular versions of MAME. I'm not familiar with WolfMAME. It shows dip switch settings and all on screen right. I'm as lost as you when it comes to viewing INP files. I've tried a couple times and can't ever seem to get it right.
D_Harris:
--- Quote from: TOK on May 26, 2008, 04:08:08 pm ---TAB is the default key for setting options in regular versions of MAME. I'm not familiar with WolfMAME. It shows dip switch settings and all on screen right. I'm as lost as you when it comes to viewing INP files. I've tried a couple times and can't ever seem to get it right.
Before my last hard drive died, I was able to watch some INPs earlier this year, but now I can't figure out how to do it, and I haven't found any instructions on the internet.(MAME is not a user friendly app).
If I had an Indiana Jones cabinet to put my PCBs in I wouldn't be trying so hard to figure out MAME now.
The instructions at Atom Arcade's website for mapping the Hydrogen Controller are atrocious an haven't helped at all.
Darren Harris
