Author Topic: Tab key not working in MAME  (Read 22001 times)
danp
  • Last login:June 09, 2008, 01:51:42 am
« on: May 16, 2008, 08:07:34 pm »
For some reason the TAB key is not bringing up my rom settings anymore, I've tried every key on the keyboard--anybody have any idea how to bring that back up to reprogram TAB is the settings key?
kaykaitkar
  • Last login:April 12, 2019, 10:03:27 pm
Re: Tab key not working in MAME
« Reply #1 on: May 16, 2008, 09:49:08 pm »
Delete the default.cfg file in your CFG subdirectory.
danp
« Reply #2 on: May 16, 2008, 10:09:31 pm »
Once I do that do I just reprogram all the controls?
  • Last login:October 20, 2023, 11:39:06 pm
« Reply #3 on: May 18, 2008, 07:49:30 pm »
What have you done differently?  Did you upgrade to a newer version of MAME?
~ DeLuSioNaL
Luigi
  • Collecting/restoring cabs
« Reply #4 on: May 19, 2008, 04:38:35 am »
Try to find the following in your cfg:
<port type="UI_CONFIGURE">
And add :
<defseq type="standard">KEYCODE_TAB</defseq>
Should work then :)
kaykaitkar
« Reply #5 on: May 19, 2008, 04:51:15 pm »
It hasnt happened to me in a long while, but I believe all the controls in each game will function the same as before the TAB worked.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #6 on: May 19, 2008, 05:36:18 pm »
You'll have to redo all the remaps you did with "Input (general)", but not the game specific ones.
Or
And add :
Should work then :)
Or just delete three lines:
<defseq type="standard">....</defseq>
</port>
and mame will return to UI_configure to the tab default.
Robin
Knowledge is Power
