Main > Main Forum
How do you secure your MAME PC inside your cabinet?
Pages: << < (2/4) > >>
HaRuMaN:
duck tape  :D
lanman31337:
I hold it at knife point and tell it not to move  :laugh2:
DaOld Man:
I placed my on a shelf, then ran a piece of mdf across the top. That baby aint going no where.
I would have used duct tape, but I was all out, I used it all holding my cabinet together...
jasonbar:
--- Quote from: RoninEditor on May 12, 2008, 02:36:03 pm ---I just sandwiched it in with big L-brackets (almost like shelf supports)... and it doesn't slide around.  Then I put an L-bracket on the top, to pinch it down, so it doesn't want to go 'up'.  I did the same thing with my bass speaker.
Thanks, Ronin (and all you smartypants out there... :))
I secured my subwoofer in a similar fashion--stuck it in the bottom back right corner & screwed in a handful of small L-brackets & just trapped it in the corner, using a couple of layers of 1/8" foam double-sided tape to give it some shock absorption.
My other idea, beyond L-brackets, was some thin-gauge strap steel (like a water heater strap system) across it in 2 directions.
Thanks,
-Jason
CrazyKongFan:
That's how I have my monitor supported ;) I have a 21" PC monitor, and it sticks out the back, so I just screwed a couple of shelf brackets on the inside to brace it...feels pretty solid and I don't think it's going anywhere. Probably not a permanent solution, but it'll do uuntil I come up with something better.
Go to full version
