Main > Main Forum
cabinet found
Pages: << < (6/6)
miles2912:
My first experience with a MAME project was buying a stripped cab.  Turned out that none of the components I wanted to use would fit.  Monitor area was too small - cp was way to small.  Basically it would not work for me at all.  What I did end up doing is stripping all the hardware out of it.  All nuts and bolts, bezel latching mechanisms grills that allow ventilation.  Everything.  It really came in handy when I went to scratch build a cab.  All the small parts and pieces really add up.  The coin door assembly alone is close to $100.
If you can find a used cab close 20-50 it will probably be more than worth it just for spare parts.
Miles
abzman2000:
right in that range, it cost me $40
Pages: << < (6/6)
Go to full version
