Author Topic: control panel edge chamfer  (Read 4185 times)
clickhea
  • Last login:August 09, 2019, 07:33:40 am
« on: May 11, 2008, 11:14:53 am »
my control panel is 3/4 i cut out the slot a bit off center so that the t molding covers the plexi.
now iam not sure what to do with the part underneath the tmolding, is it suppose to be chamfered?
i tried on scrap pieces using a chamfer bit.. but diddnt like the way it was looking..
anyone have pictures of this?
clickhea
Re: control panel edge chamfer
« Reply #1 on: May 11, 2008, 11:42:59 am »
its a 45 degree chamfer bit.. should i be using somthing different?
NickG
  • Last login:September 26, 2022, 05:25:23 am
  • Dig.
    • My Projects Page
« Reply #2 on: May 12, 2008, 02:22:55 am »
I am not sure what you mean by "part underneath the tmolding"  If you upload a picture it may help.  You should not have to chamfer beneath common flat t-molding; are you using a "lipped" type of t-molding to retain plexi at the edges or something?
fjl
  • Pixels Rule!
« Reply #3 on: May 12, 2008, 02:56:17 am »
Yeah, you can simply chamfer it. What some people did as another option was to use 1/2 inch wood for the CP instead of 3/4 so that that the t-molding covers the wood and the plexi. This way there is no extra lip of wood to deal with.
ivwshane
  • Last login:December 24, 2022, 09:35:21 pm
    • My first mame cab! (WIP)
« Reply #4 on: May 12, 2008, 03:04:09 am »
If you do it that way does that mean you have to cut the t-molding slot off center? If you do then wouldn't that leave the piece of wood be pretty week?
clickhea
« Reply #5 on: May 12, 2008, 12:05:32 pm »
i got it, i'll try and snap a pic later when i get home
massive88
« Reply #6 on: May 12, 2008, 12:23:09 pm »
Should be 5/8" MDF with 1/8" Plexi to make the 3/4" t-molding right?
mountain
  • Trade Count: (+9)
  • Last login:March 26, 2024, 11:42:28 am
    • Mountain Jukeboxes
« Reply #7 on: May 12, 2008, 12:25:11 pm »
Here is a shot I took when I was building my control panel. i used 3/4" MDF so I had to bevel the bottom edge. You can't even tell it is done this way unless you bend down and look up at it.
clickhea
« Reply #8 on: May 12, 2008, 12:56:11 pm »
thats exactly what mine looks like
fjl
  • Pixels Rule!
« Reply #9 on: May 12, 2008, 02:41:34 pm »
Whatever configuration size you want to use as long as they add up to 3/4" or whatever size the T-molding is. Normally its 3/4" for arcades.
It could. But it shouldn't be weak enough to cause a problem especially with the plexi on top also creating support for the edges. Unless someone whacks it really good with a hammer, I doubt anything will happen.
Just don't let it get wet. MDF has a sponge effect when it gets wet. Warps then dries and gets brittle.
« Last Edit: May 12, 2008, 02:45:05 pm by efjayel »
