Author Topic: CRT problem...  (Read 960 times)
LoyalistRevolt
  • Last login:June 19, 2008, 08:52:07 am
  • SEGA!
CRT problem...
« on: May 11, 2008, 12:45:32 am »
Well I found this amazing Crt monitor at a garage sale, It was the perfect size for my arcade. I got it for about 15 bucks...fast forward to about a month later when I practice mounting for the arcade. I come to find out that the monitor is broken.
Problem=Whenever I turn it on the light turns green but then shuts off and starts blinking... I never see any picture... What could be wrong?
I don't know if it would be worth mentioning but this CRT is attached to a dremacast VGA box Yes I made sure everything was attached to the Dreamcast and the power was on.
Not posting doesn't make you a noob, ignorance, stupidity, laziness, and talking trash make you a noob.
Just cause I don't post in threads doesn't mean I don't read the threads...
ark_ader
  • I glow in the dark.
Re: CRT problem...
« Reply #1 on: May 11, 2008, 02:22:52 am »
Have you tried hooking the CRT into another source like a PC?
Your dremacast VGA adapter could be at fault.
How you describe the CRT operation, it looks like no signal is being sent to the CRT.
LoyalistRevolt
  • SEGA!
Re: CRT problem...
« Reply #2 on: May 11, 2008, 12:47:10 pm »
I hooked it up to my computer and it worked fine.
SirPeale
  • Green Mountain Man
Re: CRT problem...
« Reply #3 on: May 11, 2008, 07:41:42 pm »
Then your problem lies either with your Dreamcast or your VGA box.
ark_ader
Re: CRT problem...
« Reply #4 on: May 12, 2008, 03:05:00 pm »
 :laugh2:
  • Last login:December 13, 2023, 12:03:14 am
Re: CRT problem...
« Reply #5 on: May 12, 2008, 04:32:42 pm »
I know nothing at all about the dreamcast, so i am afraid to show my stupidity by opening my mouth, but I have seen on a PC that if the PC's video card is set to a resolution that the monitor cant handle, the monitor will act like that.
Can you change the resolution settings on the dreamcast?
Ginsu Victim
  • Comanche, OK -- USA
Re: CRT problem...
« Reply #6 on: May 12, 2008, 04:36:44 pm »
No.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: CRT problem...
« Reply #7 on: May 12, 2008, 06:55:53 pm »
No.
Try setting the computer to the same resolution as the dreamcast uses.  (isn't it just 640x480@60hz, though?)  If the PC works at the same res, it's definitely not the monitor.
Robin
Knowledge is Power
