Author Topic: RGB/Sync to SVGA (or S-Video)  (Read 1395 times)
jukingeo
  • Last login:March 14, 2015, 08:25:28 pm
« on: May 09, 2008, 09:38:04 am »
Hello all,
I have a unique situation in that instead of trying to hook up an SVGA computer to an RGB, monitor, I want to go the other way.
I have a few Jamma PCB games that I would like to create a rig for.  I used to hook up these boards to a HUGE and extremely heavy 19" commercial RGB color monitor.   The monitor is getting old and flaky and frankly I don't want to move the heavy beast around anymore.   So what I would like to do is get a small lightweight video projector or even an LCD flat screen.  It seems the most common input for these is either SVGA or S-Video (Yes, I know composite is the most common but also the worst quality and most inconvenient to work with).
A video game PCB has a standard RGB with Sync output (or what is now called component video).
I have noticed that newer TV's do have component video, but I am not 100% sure if this is compatible with the old RGB-Sync standard that is used on arcade PCB's.  However, I did notice that almost all the projectors/TV monitors I have seen they have S-video.  I understand that S-video is not as good a quality as SVGA or even RGB...but would it be easier to interface with my video game PCB's?
I would like to know what my options are.   I do prefer to go RGB-Sync To an SVGA projector/monitor because then I could also hook up a computer to it later on if I want.  Thus I would then have a COMPLETE rig.
So the question is what do I need to accomplish the task?
Thank You,
Geo
"Let me tell you about the time I used a sharpened clamshell to turn a T-Rex into a T-Rachel!" -Buck  Ice Age 3
BobA
  • What Me Worry?
Re: RGB/Sync to SVGA (or S-Video)
« Reply #1 on: May 09, 2008, 09:51:08 am »
RGB with sync is NOT component video.
TOK
  • Last login:January 24, 2024, 05:14:24 pm
  • The Game Always Wins
« Reply #2 on: May 09, 2008, 11:02:21 am »
This should do what you need, but its a bit spendy.
http://www.arcadeshop.com/rgb/rgb2ntv4.htm
Ummon
  • Trade Count: (+13)
« Reply #3 on: May 10, 2008, 08:10:50 pm »
Or try JROK.
Yo. Chocolate.
Stephen Hawking
NickG
  • Last login:September 26, 2022, 05:25:23 am
  • Dig.
    • My Projects Page
« Reply #4 on: May 10, 2008, 08:37:27 pm »
^^ That is from JROK ^^
TOK
« Reply #5 on: May 10, 2008, 08:54:14 pm »
Thats correct. There was another one I saw on ebay that was cheaper... Only 25 bucks, and it only had RCA and S-Video out, no component. I missed the end of the auction though. E-mailed the seller and haven't heard back from him yeat.
I would have bought it just for having a quick way to test JAMMA boards outside a cab, I don't even care about the video quality for that.
