Main > Main Forum
Using real coins as MAME credits
danp:
--- Quote from: MameMaster! on May 05, 2008, 03:07:46 pm ---see the tutorial on retroblast.com---
http://www.retroblast.com/Articles/RetroBlast-Article-Converting-to-Token-Operation.php
that's how I wired mine. Good luck...it's actually pretty easy. :applaud:
This is exactly what I needed! Thank you very much for referring me to the site. :applaud:
GAJoe:
If you don't have or want to get coin mechs, or you want to use any kind of coin/slug/token, you can add an extension to the coin chute that directs all coins across the microswitch lever. I couldn't find the project where I'd seen this done, so no pictures to share, but I believe the guy just bent some thin sheet metal into a kind of tube and glued it to the chute. You could probably do it even easier and cheaper with some tin foil, carboard, or paper.
protokatie:
--- Quote ---If you don't have or want to get coin mechs, or you want to use any kind of coin/slug/token, you can add an extension to the coin chute that directs all coins across the microswitch lever. I couldn't find the project where I'd seen this done, so no pictures to share, but I believe the guy just bent some thin sheet metal into a kind of tube and glued it to the chute. You could probably do it even easier and cheaper with some tin foil, carboard, or paper.
Odd that you bring that up, that is exactly the thing I was going to do before thenasty offered the coin door/mech/etc thingy I bought off of him. I was planning on using cardpaper myself. It seemed the best suited for such a hack (also it is "free" since once you go through a lined paper pad you have the card paper backing).
As per the seperate coin inputs for player one and player two, there are a good number of 2 player games out there that do rely on which coin slot you activate. I will actually have to do a little modding of the coin system I got from thenasty as it is wired up for a game that didnt care which slot the coin went into and I intend on having it support 2 seperate coin inputs. (BTW, thenasty, any idea what game that system came out of? Just curious)
Fozzy The Bear:
--- Quote from: GAJoe on May 06, 2008, 07:59:32 pm ---If you don't have or want to get coin mechs, or you want to use any kind of coin/slug/token, you can add an extension to the coin chute that directs all coins across the microswitch lever. I couldn't find the project where I'd seen this done, so no pictures to share, but I believe the guy just bent some thin sheet metal into a kind of tube and glued it to the chute. You could probably do it even easier and cheaper with some tin foil, carboard, or paper.
Yeah..... That was me..... but the tubes are made from cardboard. The only downside is that you get no coin reject and it'll take anything. At home that's not a problem. The reject pushes are also connected to the microswitch lever via a piece of coat hanger wire, so you can get a credit by pushing reject as well.
I've got a lot of mechs hanging about, but I'm just too lazy to be bothered with them.
Best Regards,
Julian (Fozzy The Bear)
protokatie:
--- Quote ---I've got a lot of mechs hanging about, but I'm just too lazy to be bothered with them.
Im much more of a newb than you! And Atleast I will be dealing with coin mechs!
* protokatie takes away your ticket to the next showing of Yahtzee-on-ice.
