Main > Main Forum
cutting the plexi quick question regarding the trackball
clickhea:
the 1 1/8 hole saw will not fit through the u360 plate
do you guys think its cool if i stick with a 1 inch hole for the joysticks? or is that going to block the throw.
so far its coming out great, i just need to drill the joystick holes and its done.
csa3d:
don't forget this thread...
Control Panel Hole Sizes
-csa
nuka1195:
do you already have the joysticks? if so why don't you put a block at the top and bottom of the joystick, then push it forward and pull it back and mesure the distance between them, the blocks should be the same thickness as the plexi if top mounting and same thiskness as cp + plexi if bottom mounting. Add a little if you like.
RoninEditor:
--- Quote from: clickhea on May 06, 2008, 12:03:51 pm ---the 1 1/8 hole saw will not fit through the u360 plate
Hey there. I'm a little confused, sorry... it won't fit through the plate...? I undermounted mine so I drilled the 1 1/8" hole, then measured and routed the plate from underneath, wanting that Ms. Pacman shortstick feel. Then on the top I countersunk (and puddied in) the flathead bolts, nuts on the underside.
clickhea:
mines top mounted so iam using the plate as the guide to where the center hole should be.
