Main > Main Forum
Need: Recommendation for a USB gamepad to sacrifice.
Pages: << < (4/5) > >>
Adam_GUI:
--- Quote from: GinsuVictim on May 02, 2008, 03:46:02 pm ---Shipping might seem high, but it's coming from the UK.
It's fast shipping though. I've ordered twice from there and both times, I got it here in Oklahoma in like 2 days.
Ouch!  This I didn't notice.
Weight 8-10 Pounds boxed?  Lighter?
I noticed they had a minimum shipping of $12.
Any customs to deal with?
I know there normally isn't.  I've gotten things from South America and Hong Kong without customs.  I just want to be sure.
I've got ~$120 set aside for part for the time being.  I want to be sure I don't blow it all on the PCB and wires.
Ginsu Victim:
I ordered exactly the same thing as you and my shipping was $14 (this was two months ago).
Then a couple of weeks ago, I ordered two UltraStik 360s plus accessories for $160, plus $17 shipping.
When you see how fast you get your order, and how professional Ultimarc handles your product, you won't mind the extra that is spent.
brock.sampson:
You might want to check with Divemaster in the buy sell forum.  I think he carries most if not all of the ultimarc stuff.  I bought a few things from him a while back and he was great.  Plus since he's in the US should save you on shipping and/or customs.
Ginsu Victim:
As far as Divemaster, he only carries the Minipac with the optical connections, not the standard. (Unless this has changed)
Adam_GUI:
Got the Mini-pac today.
I'm a little confused.
I see the wire-up connection at Ultimarc.
I have the rainbow harness on the pins correctly.  That part was a no-brainer.
The color-connection path I can probably follow.  But does it alternate between button/ground and connect to either side of the main plug of the microswitch?
Or does it connect one connection disconnect period and go to the metal of the microswitch on the outside part?  (Isn't this common ground?)
I'm just not sure what I'm doing, is all.
Thanks.
Go to full version
