Author Topic: Need help finding TMNT 2player specs  (Read 1216 times)
protokatie
« on: April 30, 2008, 08:48:03 pm »
I finally decided to base my cabinet design (not so much the CP design tho) on the TMNT 2-Player cab. Although I havent seen on of these in real life, just seen some very crappy pics where I couldnt see much detail. Does anyone have this cab, or atleast some good pics and basic measurements? If not I may just use the 4 player version but scaled back a bit as my cab is a 2 player jobby.
Also is the TMNT 2P cab just a conversion of a previous basic design cab? I know the 4 player monster isnt.... :dunno
paigeoliver
  • Awesome face!
Re: Need help finding TMNT 2player specs
« Reply #1 on: May 01, 2008, 03:53:49 am »
There is no such thing as a TMNT 2 player cabinet. The only dedicated ones were 4-player units. You are simply remembering a conversion cabinet with a 2 player TMNT kit installed. It could have been anything.
Jdurg
« Reply #2 on: May 01, 2008, 03:50:19 pm »
I thought the UK version of the game was a dedicated cabinet as I don't recall if they even had a four-player version?  Heck, I've never even seen a two-player version here in the US.  I know they exist, but never saw one in any arcade.
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
paigeoliver
  • Awesome face!
« Reply #3 on: May 01, 2008, 06:42:14 pm »
Europe is a whole different ball game, different licensors and distributors and such making their own cabinets and artwork for all sorts of games, so there MIGHT have been some factory 2 player TMNT units in Europe, but that doesn't mean much and the cabinet would have still been a generic one used for many different games.
I used to have a 2 player US TMNT boardset, but it was a 4-player boardset that I replaced roms on to make into a 2 player boardset (and man did it sell for WAY more on eBay than 4 player boardsets do).
protokatie
« Reply #4 on: May 01, 2008, 08:29:04 pm »
Hmm, ok. Then no plausable 2 player version. Anyone got the specs (dimensions etc) and decent pics of a four player version? I would ofcourse scale that beast down, and make a 2 player cab out of it....
KDOG
  • Last login:September 18, 2020, 03:08:26 pm
« Reply #5 on: May 01, 2008, 08:31:57 pm »
Jakobud plans
      V
« Last Edit: May 01, 2008, 08:34:24 pm by KDOG »
Jakobud
  • Last login:May 05, 2024, 10:53:37 am
protokatie
« Reply #7 on: May 01, 2008, 10:33:01 pm »
Thanx Jakko! Thats what I needed. Would shrinking the thing by 6 inches in most aspects (not vertical of course) be a good way to shrink it down to something more reasonable? Or maybe more? (I doubt less tho).
paigeoliver
  • Awesome face!
« Reply #8 on: May 01, 2008, 11:18:01 pm »
Actually scaling a 4 player cabinet down to a 2 player cabinet is a bad idea. Start with a similar 2 player design instead, you you try to shrink that thing down it will come out looking like an Assault cabinet with a flying wing control panel attached.
Also, I have owned one of those cabinets, they are very small as 4 player machines go, the control panel has less real estate than the majority of the 2 player panels people churn out around here.
protokatie
« Reply #9 on: May 02, 2008, 12:02:16 am »
By six inches, I meant the CP would be shrunk by six inches as well. Im only going to be using a 17 inch monitor (initially anyways) so I dont need the near 3 foot width the CP offers nor the nearly as wide cab itself.
Other than starting with another 2 player of similar design, any ideas on how to reduce TMNT 4 player specs so it doesnt look too much like a MAME cab? (bear in mind as well that I will be using the neogeo/SF2 button setup, so I need a little bit more realestate on the CP than a 2 player version of TMNT)
paigeoliver
  • Awesome face!
« Reply #10 on: May 02, 2008, 02:29:53 am »
Two player Neo Geo control panel layout fits in a space way smaller than anyone would actually want to build on, so that part is not really important.
Seriously reconsider what you just said about a 17" monitor, unless you make a 1 player mini cab then a 17" monitor is going to ruin your entire project. Something shaped like TMNT with a 17" monitor in it would look like Kentucky Fried Cleveland Steamer.
For most people the display should be the most expensive part of the cabinet. A used 21" CRT monitor is only about $100.
If you really don't want it to look too much like a Mame cab then you need to rethink everything, because right now this is headed for crap-mame territory. Every machine even REMOTELY shaped like a 4 player TMNT has a 25" monitor (or larger).
protokatie
« Reply #11 on: May 02, 2008, 03:16:19 am »
paigeolive; you willing to put a pencil where your mouth is? Maybe draw up something for me so I can work on a design that would look good? (BTW I do like the CP being a wee bit wider than the cab proper)
You know what basic look I want, so even a primitive sketch would be useful.
KDOG
« Reply #12 on: May 02, 2008, 07:29:24 pm »
something like this maybe? Just expand the cp box to the left and right about an inch and that should be plenty.
« Last Edit: May 02, 2008, 07:42:13 pm by KDOG »
protokatie
« Reply #13 on: May 02, 2008, 09:35:10 pm »
Hmm, not a bad idea. Ill give it a thought. Thanx.
