Main > Everything Else
anyone else having issues with shareaza?
lokki:
I assume you mean you disabled the routers firewall.
(the connection test should tell you if it is having firewall issues).
Look under Help Connection Test
Also you may want to try and change the port used
Tools-Shareaza settings-Internet-Connection
gavkiwi:
cool, thanks for the info lokki, ill check it out when I get outta work 8)
ark_ader:
Your ISP probably have blocked all your P2P ports.
Its not a good sign.
You might get a knock on the door from the Feds.
Nuke your hard drives.
:police:
gavkiwi:
um, I dont think so ;D
I tried utorrent & Azureus, they worked fine
then I installed shareaza 2.3.1, tested my connection, said it was firewalled, the old version never said that
I disabled the firewall, then turned it back on while the program was active, soo far soo good :cheers:
AtomSmasher:
I used to use Azureus, but it was always crashing on me, so I switched to Bit Torrent
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
