Main > Main Forum
DIY Optical Sensor to Mouse Hack
Pages: << < (3/4) > >>
SirPoonga:
--- Quote from: TheManuel on May 29, 2003, 03:43:54 pm ---
--- Quote from: SirPoonga on May 29, 2003, 03:32:41 pm ---Here's what I did for my happs trackball.  I got a mouse hack (the mouse hack from oscarcontrols).  I wired the corresponding pins from the trackball wiring harness to the pins on the mouse hack.  It works great.
That would be the sure and proven way to go but it's also expensive.
I guess I'm trying to figure out a way of making work what I have already.
$10 for a mouse hack and some solder time is expensive????
Doing a mouse hack isn't hard if you already have the mouse.  It depends on the type of IR you have.  there are 3 pin and 4 pin receivers.  it just takes some trial and error to get it correct.   Witha  USB mouse it isn;t hard.  You put the power and ground to the USB power and ground.  Then it;s just determining where the X+/- and y+/- go.
TheManuel:
--- Quote from: SirPoonga on May 29, 2003, 05:37:50 pm ---
I though you were talking the whole thing, Happ trackball and everything.
And like I said on post after that, I would need a USB hub and extension cable.
But, I'll be on the lookout, because those show up at a good price every once in a while.
In fact, I'm buying a USB mouse today in Office Max that will cost me $0 after mail-in rebate.
I'll keep it as a plan B if the other thing doesn't work.
Being able to connect both to the same mouse is still attractive, though because I would only have a PS/2 cable coming out of the CP for both devices.
TheTick:
You can also get a PS/2 keyboard/mouse to USB converter for $15 from MicroCenter, and have only one USB cable out (including the keyboard interface).
TheManuel:
--- Quote from: TheTick on May 29, 2003, 06:06:38 pm ---You can also get a PS/2 keyboard/mouse to USB converter for $15 from MicroCenter, and have only one USB cable out (including the keyboard interface).
That could be sleek.
I'll check it out.
Thanks.
TheManuel:
--- Quote from: TheManuel on May 29, 2003, 06:02:39 pm ---In fact, I'm buying a USB mouse today in Office Max that will cost me $0 after mail-in rebate.
Update:
I bought the USB mouse from Office Max that will be free after rebate.
I already disassembled it and it look super simple and easy to hack so it will be a great plan B for me.
So if anyone needs a USB mouse to hack, now is teh time.
I even got more than I bargained for.  I bought a CD-RW for $10 after rebate and it is 52X-24X-52X.  It is a cheap brand but, for the price, it beats the heck out of my old 4X-4X-32X (also cheapo).
Just a heads up.
Go to full version
