May 09, 2024, 06:24:26 am
And start by drilling the backside out 1/3 of the way or so, then switch to the front and finish. It keeps the hole smoother.
Quote from: solderguy1 on April 25, 2008, 08:36:25 pmAnd start by drilling the backside out 1/3 of the way or so, then switch to the front and finish. It keeps the hole smoother.How do you make sure that it lines up on both sides?
use a Forstner bit (highly recommended). I did some practice ones on scrap, before the real ones, and it made a huge difference, the speed you use. Slow and steady and it's super clean. Fast and forced makes chunks fall out the back and WILL split your Plexi or Lexan, which you really, really don't wanna do.
I am looking to add a piece of plexi over my control panel. What size hole saw will I need to drill the holes for normal arcade buttons? How about for joysticks?
