Author Topic: Software to design the control panel?  (Read 2398 times)
dmel75
  • Last login:July 21, 2009, 11:46:29 am
« on: April 24, 2008, 03:06:46 pm »
I've got control panel button templates, spinner, trackball templates but I was wondering what you all are using to pull these things in and design your panel mockups in? I know some people are using advanced packages like Autocad, etc. I just need something simple I can pull these templates into, arrange them out and then print it on a plotter.
solowCX
  • Last login:April 29, 2012, 02:32:31 am
    • Solarcade
Re: Software to design the control panel?
« Reply #1 on: April 24, 2008, 03:27:38 pm »
A lot of people just use Microsoft Visio, which works well for control panel layouts and may be a part of the Office suite you may or may not have.
Project Solarcade - Still in progress
Dropkick_Wally
  • Last login:February 02, 2011, 05:11:01 pm
« Reply #2 on: April 24, 2008, 03:29:41 pm »
I used Microsoft Visio to design my panel.  I liked it because the printouts served as excellent drilling templates.  It does suffer from that issue with office programs not printing in the correct orientation.  Excel used to piss me off like that.  There's also some links somewhere on this site to templates specifically for Visio.
TOK
  • Last login:January 24, 2024, 05:14:24 pm
  • The Game Always Wins
« Reply #3 on: April 24, 2008, 03:37:54 pm »
A ruler, a piece of cardboard and a pencil.  ;)
emb
  • Last login:September 14, 2018, 02:01:19 pm
    • Don Honerbrink
« Reply #4 on: April 24, 2008, 04:47:36 pm »
I use visio as well. Also, you may want to check out the downloads section on the arcade controls website.There are stencils/templates (for the buttons, joysticks, etc) which you can import into visio.
http://arcadecontrols.com/arcade_downloads.shtml
(scroll to the bottom of the page):
Encryptor
  • Trade Count: (+34)
« Reply #5 on: April 24, 2008, 05:26:35 pm »
A lot of people use Google Sketchup. Mameroom.com also had a CP designer program. I have it installed but I just looked for 20 minutes and can't find the executable. Maybe someone else has it if you're interested.
Encryptor
Ginsu Victim
  • Comanche, OK -- USA
« Reply #6 on: April 24, 2008, 05:31:40 pm »
I found it in under 30 seconds
http://www.mameroom.com/files/mameroomcpd.zip
Encryptor
« Reply #7 on: April 24, 2008, 07:18:32 pm »
How did you find it? Already have a link for it? You can't search their site and there is not a download section and the software section lists nothing.
Encryptor
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
« Reply #8 on: April 24, 2008, 07:22:19 pm »
Here's the first google hit using "mameroon control panel designer" as the search criteria:
http://www.retroblast.com/Misc/MAMEroom-Control-Panel-Design-Service.php
... it's a review, and it has a link to the software at the bottom of the page :)
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
Ginsu Victim
« Reply #9 on: April 24, 2008, 08:37:33 pm »
Encryptor
I just went to their site and navigated to the custom control panel section. Found it there.
Encryptor
« Reply #10 on: April 24, 2008, 08:47:40 pm »
Encryptor
The one I downloaded from their site with the link TelcoLou posted is over twice the size of the link you posted.
Encryptor
Xb0x3r
  • Last login:August 06, 2010, 07:47:33 pm
« Reply #11 on: April 24, 2008, 09:30:47 pm »
I used AutoCAD 2008 for my design mostly because I later had to import it into MasterCam 9 to draw out the path for the CNC Router. It looks great by the way  ;D I am currently in the process of sanding everything down. I can give you my plans if you like. You can completely modify them to do what ever you want. The shape it pretty standard except it is curved at the bottom. It is 34" x 18" (at the middle of the curve)
Xb0x3r
Jdurg
« Reply #12 on: April 25, 2008, 09:57:15 am »
I just used a ruler and pencil and drew out my design right on the plywood CP face.  The unfortunate thing with this is that you have to go back and carefully re-measure EVERYTHING when designing your artwork.  (I'm in the long, slow process of doing that right now).  By designing everything on a computer and printing out a template, you'll have your exact measurements for the artwork later on.
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
Ginsu Victim
« Reply #13 on: April 25, 2008, 10:11:47 am »
I simply used a template I found here, edited it slightly, printed it off twice (for two players), cut it out, measured, and placed it on cardboard. Once I was happy with the mockup, I measured the distance from the sides and bottom to the template, then marked them on the wood. I placed the template on the wood and marked the drill points.
For my start/admin buttons, made sure to just measure them all the same distance from the top and between each other. (I did an inch and half both ways)
