Main > Project Announcements
Robotron Control Panel Mame
ArtMAME:
Robotron Wicos use Red balltops with 4" shaft lenths. Your shafts appear to be the 3.5". You can get NOS 4" shafts on Ebay right now but only the pink or light blue ones.
Also, you said you are getting an APAC? Don't you mean an IPAC? An APAC is for analog sticks, and the Wico balltops are actually 8-ways and you need an IPAC or a KeyWiz.
CheffoJeffo:
--- Quote from: ArtMAME on April 24, 2008, 03:59:02 pm ---Also, you said you are getting an APAC? Don't you mean an IPAC? An APAC is for analog sticks, and the Wico balltops are actually 8-ways and you need an IPAC or a KeyWiz.
I thought the same thing when I read the first post, but Andy added another APAC to the lineup that handles 32 buttons and 4 pots.
http://www.ultimarc.com/a-pac1.html
dgame:
--- Quote from: ArtMAME on April 24, 2008, 03:59:02 pm ---Robotron Wicos use Red balltops with 4" shaft lenths. Your shafts appear to be the 3.5". You can get NOS 4" shafts on Ebay right now but only the pink or light blue ones.
Thanks for the information. Can the Wico balltops be removed? If not I can get the correct longer shafts with the wrong color balltops and have the tops painted red.
As CheffoJeffo mentioned above I am using the version 1 APAC. I have a thing for analog controls so I will definitely be using that feature down the line. For now it will be used to get this Robotron thing up and running.
ArtMAME:
The Wico balltops cannot be removed unless you take a hacksaw to them.
Also, if the APAC is infact a gamepad emulator, it may not have actual keyboard key press functionality. I ran into that when I hooked up a USB KeyWiz from GGG. It did not detect any actual keyboard key presses. I opened up the game controllers icon from the Windows control panel and was able to detect game pad button presses.
That may be important to you if you plan to use any admin buttons on your CP or in you cabinet. You may need an additional PS/2 (keyboard emulator) to get ESC, TAB, ENTER, etc.
Or you could just keep a keyboard inside the cabinet for admin or use a wireless keyboard outside the cabinet.
(+_+):
--- Quote from: dgame on April 24, 2008, 12:30:07 pm ---I am going to interface the sticks and buttons with an A-PAC. It will be a standalone Robotron control panel. I am going to replace the fire stick with a real Wico.
The 360 is for all the regular games.
This is for Robotron / Crazy climber and I have another project that will use two CH Flightstick Pro's for dual stick / multi button Tank type games like Assault and Vindicators:
I'm a Robofanatic and use 2 U360's that can easily double and triple your game play options. I would consider myself an expert player who is very picky about maneuverability when it comes to Robotron. Actually especially when it comes to Robotron. I love the U360's especially for Robotron and mutant storm. I personally think they kick tail. I tried going down the path of building my own, wasted money for nothing and accidentally sawed deeply into my palm in the process. Not worth it at all.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
