Main > Artwork
hp design jet 24" large format printer would it do?
<< < (2/2)
amadama:
what is the printer model?
BASS!:
It may just be a "draft" printer, but if you play with your ink saturation you can get a dull gray to be jet black, or a light pink to be the exact dark red. You may need to invest a little cash, but you could always pick up a cheap colorometer and a monitor profiler off ebay that may help you do what your wanting to do. If you would like to find a good reseller in your area, check google. Look up (your reigon) reprographic / print or printing supplies. Good luck and let us know what you make!
G1zm0:
hi its works printer  so dont want to mess with it to much, but will rig up to laptop and c what i can do with it, i think it is a draft printer they use it for maps
Yarb:
As much as I love recycling I have never seen an aftermarket inkjet ink that prints as well as the HP ones. The color saturation is usually off and they tend to bleed (Look fuzzy) on most stockes. IIRC the DesignJet 550 takes seperate inks and printheads so if you change the inks do not dispair when the print does not improve right away, you will need to print enough to work all the ink already in the supply tubes and printhead tank out of the system.
Yarb
Navigation
Message Index
Previous page
Go to full version
