Main > Main Forum
How to hack steering controls to an XBox?
Pages: << < (2/2)
Beley:
--- Quote from: unclet on May 28, 2003, 07:05:21 pm ---Does an XBox controller have two potentiometers inside?
I saw a controller and could not be certain they had some pots inside.
Also, do the XBox pedals have pots in them?
Regards,
UncleT
it acually has 6, 2 for each joystick, and one for each trigger
by pedal do you mean trigger(the 2 "buttons" on the unserside of the pad)?
Pyronious:
You should also be aware that the A, B, X, Y, Black and White buttons on the Xbox controller are pressure sensitive and send an 8-bit digital word back to the Xbox to tell it how hard it's being pressed.
The analog sticks and the two triggers have 16-bit resolution.
Patrick
Howard_Casto:
--- Quote from: AX on May 28, 2003, 04:29:35 pm ---in theory you should be able to buy the happ usb interface or equivaent and hack the usb connection over to an xbox contoller connector using and extension cable.  the xbox has native usb. Now i have not done this with a wheel but have done it with a keyboard.
How would this help as there aren't drives for a keyboard or mouse in xbox games?  For mame yes, but the poster never said he wanted to use mame he said driving games.  :)
AX:
you guys keep saying that but i have no problem using my keyboard in a game.  although its a pain it does work.
Pages: << < (2/2)
Go to full version
