Main > Main Forum
Connectors for swappable control panels
Civilan:
I plan on using a card edge connector with fingerboard as paigeoliver suggested.
BTW, a normal card edge connector is much like an old ISA slot on a motherboard.
I liked this approach because I wouldn't have a cable dangling from the uninstalled control panels.
Cheers,
Civilan.
SirPoonga:
--- Quote from: Civilan on May 28, 2003, 02:09:46 pm ---I liked this approach because I wouldn't have a cable dangling from the uninstalled control panels.
I don't have dangling wires. The cable fits nicely inside the cp when not in use :)
rampy:
--- Quote from: SirPoonga on May 28, 2003, 02:54:00 pm ---
good.. there's nothing worse than a loose dongle =P
rampy
SirPoonga:
--- Quote from: rampy on May 28, 2003, 02:55:59 pm ---good.. there's nothing worse than a loose dongle =P
rampy
SMACK
*shrug*
Hoe:
I used DB37's. They're like a parellel connector, only with 37pins instead of 25. I use the top row of pins for player one, the bottom (smaller row) for player two.
