Main > Main Forum
Connectors for swappable control panels
wee beastie:
I didn't use a patch panel. They sell the plastic boxes at telco stores that have a faceplate that can hold 6 ethernet jacks. So, I just used one of the black plastic boxes with that faceplate. Nice and cheap. Didn't feel like shelling out the cash for a patch panel.
edit: I reread your last post. Yes, I used the 110 box and had a faceplate that could hold six jacks.
MinerAl:
The only thing I'd worry about with using RJ-45 would be my dumb as$ would keep putting the wrong connectors in the wrong sockets. Do you color code them or something?
mahuti:
The only problem I have with ethernet cable is the small size of the wiring. I may be wrong, but it seems like the guage on that stuff was about 24 ga. if I recall correctly. Generally everybody seems to prefer 18 for grounds and 20 for wiring connections.
Hoe:
24 is fine. I believe most telephone wire uses 26guage, which you'll be fine with, too. Using 24+guage seems to be such taboo around here.
pmc:
--- Quote from: mahuti on June 02, 2003, 09:10:21 pm ---The only problem I have with ethernet cable is the small size of the wiring. I may be wrong, but it seems like the guage on that stuff was about 24 ga. if I recall correctly. Generally everybody seems to prefer 18 for grounds and 20 for wiring connections.
Can't be worse than the SCSI ribbon cable I've been working with. Must be 26 or higher. One or two strands broken off is significant. Stripping it is tricky. At least cat-5 cable is solid core, thicker, easy to get tons of, and very easy to work with. You could even pick up a handful of Ethernet patch cables with the connectors already in place -- I threw away a dozen of them last night! If I do this again, I'll use telco cable instead of messing with 24 gauge stranded mounting wire and the SCSI ribbon cable. Hell, I might even redo all of this work right now. I wish I'd thought of this before. I had assumed that people were using lighter gauge wire because of some electrical requirement.
