Main > Main Forum
Design Idea - Expanding Modular Control Panel
Pages: << < (4/4)
ironpoet:
--- Quote from: NickG on April 16, 2008, 10:58:24 am ---You could inset the top flaps or slightly raise the control modules to that the are flush, mating them with 45° angles or rabbeting.
That's an excellent idea.  It would also allow me to raise the modules up and leave a bit more room for deeper controls.  I'm not sure how far down a rotary joystick hangs, for example.
ironpoet:
--- Quote from: stan2323 on April 16, 2008, 08:28:50 am ---http://www.woodworker.com/cgi-bin/FULLPRES.exe?PARTNUM=129-971&search=Hardware Drawer Slides - Ball Bearing Box Drawer
I used these a few times for other projects.  They are very strong and very little wobble.  They ones I got were the 100 lb pair.  I would think they would be good for what you want but the company has stronger one but they are more expensive.  You can get them in what ever length you need.
Thanks for the link!  If I can work out a design using drawer slides, that should make the design a lot more reliable.  Those 14-inch slides might be a bit long, though, since I'd like the default size to be less than 28-inches.  I suppose I could offset the slides, though...
stan2323:
--- Quote from: ironpoet on April 16, 2008, 04:34:05 pm ---Thanks for the link!  If I can work out a design using drawer slides, that should make the design a lot more reliable.  Those 14-inch slides might be a bit long, though, since I'd like the default size to be less than 28-inches.  I suppose I could offset the slides, though...
Here are some 12''s.
http://woodworker.com/cgi-bin/FULLPRES.exe?PARTNUM=115-187&search=Hardware Drawer Slides - Ball Bearing Box Drawer
And some 10''s.
http://woodworker.com/cgi-bin/FULLPRES.exe?PARTNUM=905-025&CARTID=200804165665026079--1
telengard:
Nice design!
Just make sure those edges holding down the modules is rock solid.  I speak from experience.   :)
~telengard
Pages: << < (4/4)
Go to full version
