Main > Main Forum
What Joys are these?
kowal:
LS56 100%
only LS56 have red slave under actuator
HaRuMaN:
Do they mix and match mounting plates then? Because all the pictures of the LS56 I can find looks different.
paigeoliver:
I can't vouch for that specific joystick, but different joysticks are known to change over time, and there are variants and so on.
--- Quote from: HarumaN on April 15, 2008, 09:52:58 am ---Do they mix and match mounting plates then? Because all the pictures of the LS56 I can find looks different.
HaRuMaN:
Yeah, I went ahead and ordered the LS56's. Regardless of what mounting plate it comes on, it looks like they connect to the mounting plate the same way, so I should be able to swap them myself.
Ummon:
--- Quote from: HarumaN on April 14, 2008, 07:07:09 pm ---Top view:
Ah, da ki-tty. Yeah, I figured they were semitsu. I think mine work okay. I haven't tested them much. Tetsu96 has one of these and he swapped in Happ Comps. I think I'll keep the Semitsus.
