Main > Main Forum
Mamemarquees.com Ultimate marquee option:Please explain
Ginsu Victim:
Laminate with, I believe, UV protection to keep it from fading, and to protect it from being as easily damaged.
You still want to put plexiglass over it. It's just high quality photo paper.
FrizzleFried:
I have both styles. Get the ultimate. Standard = high quality photo paper essentially. Ultimate = much more rugged, much more durable...like the material used in CPO's.
scottp:
It is totally different materials: the standard is a high quality photo paper that backlits well. and the Ultimate is a backlit film that is front printed and then overlaminated to protect the front, gives it the same mylar feel and it also makes it stiffer.
Ginsu Victim:
Thanks for coming in and straightening things out, Scott. Perhaps a rewording on the site is in order? This question tends to come up a lot.
Minwah:
--- Quote from: FrizzleFried on April 12, 2008, 10:45:49 am ---I have both styles. Get the ultimate.
Wot he said :)
