Main > Everything Else
What can I use to clean metal?
Kevin Mullins:
Soak the grill down with a can of oven cleaner, place it inside a plastic garbage bag and let it set for a couple hours or even overnight. Then just wash with regular hot soapy water.
Do this outside, wear rubber gloves and don't breath the oven cleaner fumes.
Ed_McCarron:
--- Quote from: Peale on April 12, 2008, 06:47:07 am ---You should have been cleaning the grill after each use. At the very least, every few times. You're putting food on it, you know. Bleaugh!
Or, just give the grill some Cipro. :)
Toss it and order a new grill (not the whole thing, just the metal grate...). Then, follow up with proper maintenance. I spray mine with olive oil before cooking - the food scrapes right off afterwards.
shmokes:
I used to use a little hibachi (no idea if that's spelled right) grill, and after cooling I'd turn it to high, close the lid, and set a timer for 10 minutes, to burn everything into easy-to-clean ash.
I got a cool new grill for Christmas, though, from the in-laws and the grill has a ceramic coating on it. Instead of burning everything into easy-to-clean ash, it seems to just fuse the stuff to the grill and make it near-impossible to clean. Too bad. But if you've just got a metal grill, my method takes all the work out of cleanup.
Jdurg:
Some 80% fuming Nitric Acid will get rid of the gunk, possibly nitrating some of the organic matter, and removing the metal grill quite quickly. :P ;D
IA1NY:
Simple Green neat. Get or make a pan and let the grate sit in it overnight, then scrub with a green Scotchbrite pad or steel wool. Repeat if necessary. Simple Green is "non-toxic" so be sure to burn in the grate before the next time you use it.
Much luck!
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
