Main > Main Forum
Hardwiring mice
Chris:
See http://www.arcadecontrols.com/arcade_input.shtml#Y-Adapters .
--Chris
_Iz-:
Hack the spinner directly to the compusa trackball pcb leaving the original functionality intact so both function simultaneously. No extra mouse required...
Should be super easy for the spinner, just 2 signal wires to one of the axis, power and ground...
TheManuel:
--- Quote from: Chris on May 27, 2003, 04:17:13 pm ---See http://www.arcadecontrols.com/arcade_input.shtml#Y-Adapters .
--Chris
Yeah but those are too expensive. I'm trying to look for a cheap alternative.
TheManuel:
--- Quote from: _Iz- on May 27, 2003, 04:25:50 pm ---Hack the spinner directly to the compusa trackball pcb leaving the original functionality intact so both function simultaneously. No extra mouse required...
Do you mean buying the optoelectronics separately and wiring them to the trackball?.
How can I leave the trackball functionality intact otherwise?
Tiger-Heli:
--- Quote from: TheManuel on May 27, 2003, 04:07:00 pm ---http://store.yahoo.com/trianglecables-site/7inps2ycabtw.html
Don't know if it works or not, though. . . :-(
If you order one, I'd like to know if the Keyboard side of it works and if the Keyboard LED's function correctly with it.
--- Quote ---
I have looked at those in the past but I think that only works for laptops that have the capability to take in a mouse and keyboard or two mice through the same port. I'm not sure it would work on an ordinary PS/2 port.
The one you are talking about is one mouse and one keyboard to a laptop PS/2 port. They don't work for MAME. The one I linked two is 2 mice or 2 keyboards to a desktop (or laptop) PS/2 port. But I haven't used one, so I can't say how well they do or don't work.
