Main > Main Forum
Whats the depth of your 2 player cp?
Pages: << < (4/4)
paigeoliver:
It is deep enough as long as the trackball plate fits on it, that is your minimum and the minimum is more than comfortable (most Streetfighter machines you played on were probably conversions of early 80s titles with panels only about 5-6" deep.
Too MUCH depth is actually a fairly common mistake. In general your design should be such that the control panel doesn't jut out more than a few inches past the coin door (not at all is even better).
northerngames:
--- Quote from: paigeoliver on May 01, 2008, 04:06:37 am ---It is deep enough as long as the trackball plate fits on it, that is your minimum and the minimum is more than comfortable (most Streetfighter machines you played on were probably conversions of early 80s titles with panels only about 5-6" deep.
I remember the short stubby converted Cp's and could not stand them let alone play them with a buddy without being squeezed in.
some may like them that way but if you stick your tongue out and it toach's the screen it is a little to close for comfort for most gamers prefference's and would have to argue that (not is all is no good period no better) unless your going blind or a mini-me.
Pages: << < (4/4)
Go to full version
