Main > Main Forum
Golden Tee Mame project
Pages: << < (2/2)
phishpac:
Some searching on the forum will provide you all the answers you are looking for in your project.  Take the time to use the search feature and you will find many threads of people doing similar builds.
You can use any type of connection you want with your wires.  You can use quick disconnects (the most popular, they are the male and female contacts the join together), crimp on connectors, and if you really wanted to you can solder the connections.
Your basic jamma pinout is here:
http://wiki.arcadecontrols.com/w/images/9/93/Jamma-pinout.gif
This will help you in your wiring of the controls.
I would suggest visiting the BYOAC wiki at:
http://wiki.arcadecontrols.com/wiki/Main_Page
It is an easy to navigate source of information that will help you greatly in your build.
good luck and keep us updated
Fozzy The Bear:
--- Quote from: wrighty on April 10, 2008, 12:28:46 pm ---From what I understand the JPAC acts as an interface between the jamma and the PC, am I correct with this?
Forget the J-Pac your cabinet isn't wired for sticks and buttons and given the number of wires you'd have to run to the J-Pac it's not worth using a J-Pac and the existing wiring. Mostly because the Golden-Tee machine does not have a complete JAMMA loom.
Fit the PC with the Arcade VGA card to give you video that will drive the arcade monitor and either get an I-Pac and wire your controls to that, or get a Keywiz http://www.groovygamegear.com and wire them to that.
Many of the basic questions you are asking here are also answered in the http://wiki.arcadecontrols.com/ read read read!!!
Also!! Buy Saint's book!! you'll find it on Amazon....   http://www.amazon.co.uk/Project-Arcade-Machine-Digital-Lifestyle/dp/0764556169/ref=sr_1_2?ie=UTF8&s=books&qid=1207845584&sr=8-2 It's invaluable to all Arcade noobs!! lots of good advice... buy it and read it cover to cover.
Best Regards,
Julian (Fozzy The Bear)
wrighty:
Cheers for that! Sorry for all the newbie posts! Its just I have had the machine in my garage for months and have a week to at least start! Ill keep you posted!!
wrighty:
Book has been ordered and after a few posts in other areas I have my plans!! Just one quick last noob question! In my golden tee machine I have 2 speakers in the front (which off the top of my head are connected to my Jamma loom). Can I use the speakers for my project or will I need some PC speakers to take the sound? It would be nice to have the Cabinet speakers for authenticity though! Im guessing the only way I could do it would be by hacking a PC amp somehow?
Cheers again!
phishpac:
the book has a whole write up about hacking a pc speaker amp.  wiki has info too
Pages: << < (2/2)
Go to full version
