Main > Main Forum
U360 Help *Anyone Else Have This Problem?*
Spacejack:
The default setting for joystick deadzone is 30 I think. I'm not sure yet what a good setting would be for fighters, but have found that setting it a bit lower was good for a couple of old 4-way games. On the other hand, that may have been a false first impression. What I am pretty sure of, though, is that for games that use real analog joysticks (Road Runner, Harrier, Paperboy, the 49-way on Sinistar, etc.)... for those you want the deadzone at zero and configure your mame settings (in the Tab menu in-game) to eliminate the joystick digital input leaving only the analog axes.
u_rebelscum:
--- Quote from: Spacejack on April 24, 2008, 07:20:53 pm ---The default setting for joystick deadzone is 30 I think.
Very close: 30%. In mame.ini, that's 0.30. :)
--- Quote ---...for games that use real analog joysticks ... you want the deadzone at zero and configure your mame settings ... to eliminate the joystick digital input leaving only the analog axes.
Definitely. VERY important.
