Author Topic: Versa Balltops, U360 Balltops, colors, threads, washers, HELP (please)!  (Read 1742 times)
arzoo
  • Last login:April 14, 2024, 11:15:11 am
  • Robots WILL kill you.
    • LEDBlinky
Hi All,
Originally my cp had all Happ Supers with battops. I recently replaced two of the sticks with U360 balltops (red) - I really like the U360s! So I decided to replace the battops on my Supers with GGG Versa's - red. Here are my initial observations...
  • The Versa "Red" is darker than the U360 "Red".
  • The height of the balltops do not match exactly - the Versa is maybe 1/8 to 1/4 taller (mounted under 3/4 MDF).
  • The original Super dust washer hole is larger than the Versa shaft (due to the plastic sleeve used by the Super).
I can live with the difference in the stick heights, but I would really like to match the balltop colors. I've been searching all the forum threads and I believe the ball thread for the Versa is .250 and the U360 is 6mm - so no chance of interchanging.
So... does anyone know of bright red balltops with a .250 threads or dark red balltops with 3mm threads?
As for the dust washers, I see that Randy sells replacement washers for the Versas, but they are made of metal and cost $2 ea. Any idea on where I can purchase black plastic washers for the Versas?
Thanks!!!
Update: I see that the U360 uses a Sanwa JLW base. I also found lizardlickamusements selling Sanwa balltops. The LB-35 (Standard 35mm size ball top fits JLF-TP-8T and JLW-TM-8) comes in dark red, but I'm not 100% sure it has the 6mm thread.
« Last Edit: April 06, 2008, 05:18:39 pm by arzoo »
Robots will kill you.
Arcade Addiction
fjl
  • Pixels Rule!
Email them and ask. They're usually prompt at answering questions. By the way, who is that on your avatar?
Bender
Check here: http://www.akihabarashop.jp/ it's a little hard to navigate, but I think they have what your looking for too
let us know what you find out
Isn't that John Lithgow from Buckaroo Banzai?
« Last Edit: April 06, 2008, 09:37:30 pm by Bender »
fjl
  • Pixels Rule!
Huh, your right but i always thought that was John Candy.
arzoo
    • LEDBlinky
Correct... Buckaroo Banzai Across The Eighth Dimension
Thanks.
Arcade Addiction
ids
  • Last login:April 16, 2023, 05:43:28 pm
  • Fighter Captured
fwiw, I have installed the Seimitsu LB-39 bubble-tops on my U360's (from LizardLick).  Not sure if that helps at all.
fatfingers
  • Last login:January 26, 2015, 10:15:43 am
  • Got UltraStiks?™
For what it's worth, this site seems to claim LB-35s fit on U360.  Also, I have ordered some from Akihibara Shop (sp) and they fit my U360s.
Good luck.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
arzoo
    • LEDBlinky
Thanks for the replies.  :cheers:
I called Lizard Lick Amusements and they confirmed that the LB35 does fit the U360. If I go with the dark red, it should match the GGG Versa's. Now I just need a dust washer with a 3/8" I.D. hole.
Arcade Addiction
Note that while the thread on the Sanwa/U360 is different to the GGG 'Versa' shaft, it will 'fit', as long as you don't mind the shaft cutting a new thread in the brass insert of the ball top.  I did this as I wanted a bright red ball on my old 49-Way with stainless GGG shaft.  While not 100% ideal, it did work fine.
arzoo
    • LEDBlinky
Good to know - thanks Minwah!
Arcade Addiction
arzoo
    • LEDBlinky
Re: Versa Balltops, U360 Balltops, colors, threads, washers, HELP (please)!
« Reply #10 on: April 10, 2008, 09:42:27 pm »
Here's a quick update - I received my Sanwa balltops from LickLizard today. Turns out the Sanwa Red is exactly the same as the red ball-top that comes with U360 - it looked darker on the webpage  ::). So that didn't really help me match them to the Versa's. I wonder where Randy gets his ball-tops from?
Minwah - I figured I might as well try mounting the Sanwa's on the Versa shaft as you suggested. But I think the Versa shaft for the Super must be different than the Versa shaft for the 49way - because the threads must be like 1/4 in diameter. There's no way the Sanwa ball-top could fit, unless maybe I removed the threaded brass insert entirely - even then I don't think the hole would be wide enough.
Arcade Addiction
