Author Topic: Coindoor/coinmech procurement questions  (Read 1313 times)
protokatie
« on: April 04, 2008, 10:41:39 pm »
My basic plan for making my cab always involved getting the guts out of the way first before making the actual cab (So I knew what clearances I was dealing with as well as sizes, etc)
My next purchase will be for a complete coin door + coin mech unit for a 2 player cab. Which ones would you peeps recommend for a low cost but authentic looking complete coin acceptor system? Does DM have some good deals? Are there ones I should avoid (IE the cost vs quality ends up not being worth it)?
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 02:20:28 pm
Re: Coindoor/coinmech procurement questions
« Reply #1 on: April 04, 2008, 10:54:20 pm »
cheapest one would be getting a used one. Check B/S/T.
I can offer you one over/under complete with .25cents mech and buckets for $25 plus S/H in USA.
Might need you to touch up the paint or you can do a pretty job by stripping it first before painting, but otherwise, its good enough.
Free VGA Breakout Cable
protokatie
« Reply #2 on: April 04, 2008, 11:05:00 pm »
Is it a 2 coin mech system or just a single? If it has two coin slots + 2 coin mechs you may have a deal.
Thenasty
« Reply #3 on: April 04, 2008, 11:25:00 pm »
2 slots.
nuka1195
  • Last login:April 18, 2020, 08:47:25 pm
« Reply #4 on: April 06, 2008, 02:57:57 pm »
if protokatie is not interested, i may be.
I'm limited on height but am looking for a two slot with 25 cent mech. Do you have a picture and dimensions?
protokatie
« Reply #5 on: April 07, 2008, 03:34:05 pm »
Think I may have beaten you to it, Im just waiting for thenasty to get a total (S&H) price to me so I can write a cheque ;)
nuka1195
« Reply #6 on: April 07, 2008, 04:35:18 pm »
Sounds like a very good deal.
May not have fit anyways, i only have app 18" in height with 16-1/2" inside the cabinet.
Good luck
protokatie
« Reply #7 on: April 07, 2008, 06:29:02 pm »
Good luck
Seems like a good deal for me, as I stated earlier I am going to design the cab around the fundamental components (The CP is based on the controls, and the cab will be based on the sizes and config of the CP, coinbox, monitor, etc). And from the looks of the coinbox, I may have to scale up the base of the cab a bit for it to work (esp since I am planning on have a full cased computer in the base).
