Main > Everything Else
How Stonehenge Was Built?
<< < (3/3)
patrickl:
I saw a horizontal beam laying on two verticals. Not sure if it was in this clip, but he sure managed to do it.
danny_galaga:
--- Quote from: Samstag on April 03, 2008, 11:45:08 am ---
--- Quote from: tk_42_1 on April 03, 2008, 11:34:14 am ---Ok, so that proves a way to place the vertical beams in place.  How the hell is he going to get the horizontal cross beams on?  I can't see him using that same see-saw method to get those blocks 8-10 feet into the air.
That same trick will work quite a bit higher, as long as you strengthen the vertical supports.  That doesn't answer the question of how you slide them into place on top of the vertical stones, but I'm sure he has that worked out by now.  I think I first saw that video a few years ago.
dunno if he addresses it. but you could see-saw it to any height. do it parallel to the vertical bocks, then wiggle them over to the verticals...
Navigation
[0] Message Index
[*] Previous page
Go to full version
