Main > Project Announcements
Mame With No Name! - now with more pictures (It's alive!!)
<< < (3/3)
valiant:
How easy was it to take the back off the TV?  That's my next job!
toff74:
Hi Valiant..
Pretty easy actually. Was just 6 'cross headed' (thats a technical term) screws in the back and with a bit of a wiggle it was off.
One thing i will mention is that the TV becomes very unstable without the back. Be very careful when tipping/lifting. It could quite easily end in  :cry: Definitely a 2 man job.
I dont know if you can see in the pictures, we secured both the front (screw through the front inputs)  and back base plate to a thick sheet to stop this.
Toff74
toff74:
Valiant
Here is what i meant... Just a screw through the front inputs section. This, as well as some through the back plate.
Toff74
taternutz:
What are you using for the controller interface?? Just curioos because i have the Ipac and was going to buy the ultimarc adapter..
toff74:
Hello
Taternutz:
I'm using a minipac, see here:
http://www.gremlinsolutions.co.uk/products/minipackit.htm
the 4 way in the middle is commoned up with player 1 as are the buttons (1 & 2), i also have a player 1 credit and start and a player 2 credit and start. Admin functions use the shift button (player 1 start + another).
The trackball is an x-arcade model. I know x-arcade dont have the greatest rep around here, but it has a really good action, is smooth and comes with a load of buttons and uses USB. It's just a glorified mouse. The 2 buttons on the inside of the player 1 and 2 start are the left and right mouse button.
No problems at all to report..
Oh, and i've now fitted speakers to the cab and its getting painted.. pictures tomorrow.
Toff74
Navigation
[0] Message Index
[*] Previous page
Go to full version
