Author Topic: Been out of the scene for awhile -- Jamma to Mame question  (Read 909 times)
Hoagie_one
  • Um....whats a cabinet
« on: March 27, 2008, 03:50:46 pm »
Are there any tutorials that you guys can point me to that will point me to the easiest ways to connect a Jamma or Jamma+ cab to a PC for some Mame action? Cheap is a plus.
SavannahLion
Hoagie_one
Re: Been out of the scene for awhile -- Jamma to Mame question
« Reply #2 on: March 27, 2008, 04:22:34 pm »
what about adding additional buttons.  The jamma cab I am getting has 3 buttons on it, anyway to make it a 6 button setup?
joshlindem
  • Last login:August 17, 2013, 12:21:24 am
« Reply #3 on: March 27, 2008, 04:27:35 pm »
check out the online store from Ultimarc.  It's doesn't jump out and tell you, but they sell buttons there as well in any of the colors you may be looking for.
Scroll down this page http://www.ultimarc.com/JShopServer/section.php?xSec=6 to the Classic Push Buttons
And if you're looking for 6 buttons, I bought this from them.
http://www.ultimarc.com/ipac1.html
grbgemen
  • Last login:April 11, 2014, 10:30:18 am
« Reply #4 on: March 27, 2008, 05:04:21 pm »
from the ultimarc site about the j-pac:
What controls does the JAMMA connector support?
The JAMMA standard supports 2 players with 3 buttons per player. There is an unofficial addition to this, some cabinets wire a fourth button. Plus coin, start etc.
Thats not many buttons, what about any others?
Game boards which need more buttons have an auxiliary button connector which can vary in type. This is not part of the JAMMA standard. The J-PAC caters for these extra buttons by having screw terminal inputs for these extra inputs.
Inputs supported directly through the JAMMA connector are:
Player 1 and 2 joysticks, Player 1 and 2 buttons 1,2,3,4. Coin 1, Coin 2, Start1, Start2.
Inputs supported by the screw terminals are:
Player 1 and 2 buttons 4,5,6,7,8.
Note that button 4 can be connected via either method as some JAMMA harnesses route this button through the connector.
If you have a 4 player cabinet you can use an I-PAC2 board as well as a J-PAC and plug the I-PAC into the pass-through connector of the J-PAC. You will need to re-program the I-PAC board for correct player 3 and 4 keycodes.
Hoagie_one
« Reply #5 on: March 27, 2008, 05:47:00 pm »
awesome.  thanks for doing my research for me.  I really appreciate it.
Mike
