Author Topic: FS: MAME Arcade Controller willl trade for PS3 [Michigan]  (Read 1510 times)
TheTick
  • Last login:December 21, 2009, 12:24:27 pm
  • I.P. Daley
« on: March 26, 2008, 04:22:05 pm »
Similar to an arcade cabinet, but without the monitor.
This can be hooked to a computer to display on a monitor, a big screen TV (like I've done in my living room), or you can open a laptop so it is flat and slide it into the back of the unit.
It connects to a PC via a single USB cable. I have the controller configuration files optimized for MAME , so the unit is ready to play. Works with other games as well, but may require additional configuration.
Authentic HAPP arcade controllers, buttons and trackball. Spinner (from Oscar controls). Functional coin door takes quarters, or press the reject button to register a coin being inserted. They even light up. There are also rugged cup holders installed on either side. Also have Oscar 4-way restrictor plates for the left controller.  The controller interface consists of an Ipac4 and two Oscar optical trackball hacks.
There are amplified speakers built into the system. The console works great, only the pinball controls/plunger are not hooked up, but I will include the extra parts to get them functioning.
Asking $400
« Last Edit: September 05, 2008, 11:21:23 am by TheTick »
Mucal invader, is there no end to your oozing?!
DJ Infinity
  • Last login:January 19, 2012, 03:48:16 pm
Re: FS: Arcade Panel/Podium (1/2 a cabinet) in Detroit, MI
« Reply #1 on: March 26, 2008, 05:28:04 pm »
I like it!!!! you take payments?  ;D I'm tapped out after buying my Blitz stuff.
If You Are Going To Meddle At Least Listen
Red
  • Last login:November 07, 2017, 08:37:51 am
« Reply #2 on: March 26, 2008, 05:47:59 pm »
Nice!  You got any build plans for it?
Red
TheTick
  • I.P. Daley
« Reply #3 on: March 26, 2008, 08:02:19 pm »
Thanks.
For plans, I just have a Visio template for the control panel. The rest is pretty much just measurements for the individual pieces that make up the base and enclosure.
Hoagie_one
  • Um....whats a cabinet
« Reply #4 on: March 27, 2008, 08:49:23 am »
How sturdy is it when being played?
TheTick
  • I.P. Daley
« Reply #5 on: March 27, 2008, 09:07:45 am »
It's pretty sturdy for most games. I wouldn't recommend using the laptop in the back feature with Street Fighter though, even with some squishy foam in there, it'll get banged around  ;D
It rocks a little when people get a bit too into a game, but even that can be fixed by attaching something like a 2'x2' MDF or particle board to the base.
Lilwolf
« Reply #6 on: March 27, 2008, 12:36:27 pm »
Oh, that would look great infront of my projector.
I dont think I could buy it right now...  But if you got the cash for it, could you hold it for a month while scheduling a pickup?  (I'm in southern ohio, but go up that way once every other month)
TheTick
  • I.P. Daley
« Reply #7 on: March 27, 2008, 02:09:44 pm »
Holding it shouldn't be a problem. Would you mail a check?
Lilwolf
« Reply #8 on: March 27, 2008, 02:51:16 pm »
wife would be the problem.   I'm going to show her tonight.
If I got her approval, then the rest of the arrangements can be made pretty easy.
TheTick
  • I.P. Daley
« Reply #9 on: March 27, 2008, 10:25:37 pm »
Still available  ;)
TheTick
  • I.P. Daley
« Reply #10 on: May 06, 2008, 11:02:08 am »
Bump.....  Still available
TheTick
  • I.P. Daley
« Reply #11 on: July 03, 2008, 12:08:38 pm »
Still available...  ::)
TheTick
  • I.P. Daley
Arcade coontroller will trade for PS3 [Detroit, MI]
« Reply #12 on: September 05, 2008, 11:19:57 am »
Still available.  I would also consider trading for a PS3 w/ wireless controllers.
