Main > Main Forum
8 way Super vs Rotary - anyone compare?
paigeoliver:
I have found that all Happ Sticks are way too diagonal happy. They all seem to have larger diagonal areas than primary areas. I try to avoid using them altogether.
HeadRusch:
I dont sense any difference in diagonal response between my J-STick from Ultimarc and the Happs Supers I have in there now....of course I didn't route, so the sticks are on the stubby side, which is just how I like them (its the way I hold them).
Does the happs 360 require an external power source to run it? Thats the one without switches I believe, right? Or is that the happs 48-way......can they be used interchangably?
nighthawk2099:
Well, I was wondering how does the Happs Rotary have the same functionality in say StreetFighter or MK as the 8 way does?
If I had a choice and wanted to be able to play both the Streetfighter style games and Contra style, should I go with the Happs Rotary for both or dedicate joys for each?
