Author Topic: joust power supply no longer working...?  (Read 15669 times)
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« on: March 25, 2008, 10:21:01 pm »
so i look up at my joust cabinet which has been running fine for five or six hours today and see that the monitor is no longer on...
the coin door lights and p1/p2 buttons are lit...
i walk over and shut the game off...then turn it back on...
there is no normal 'turn on buzz' and the monitor flickers white very quickly and goes back to nothing...
i do this once more before deciding to give it a rest...
after about five minutes...i try again...same deal except the monitor doesn't flicker at all...it's just blank...
being that this is my first cabinet...i have no idea where to start...
it's been working great for the two weeks that i've owned it so far...
who knows...maybe the monitor is fine and it's something else not sending it a signal or something...
what should i be looking for...?
thanks in advance... :cheers:
« Last Edit: March 28, 2008, 10:22:10 pm by fixedpigs »
whammoed
  • Last login:Today at 02:27:40 pm
  • Crack don't smoke itself
    • NiceMite
Re: joust monitor no longer working...
« Reply #1 on: March 26, 2008, 01:12:55 am »
Does it play blind?  (when you coin up, etc do you hear the game play sounds?)
RetroACTIVE
  • Last login:January 28, 2024, 04:27:52 pm
  • Gramps
« Reply #2 on: March 26, 2008, 09:20:33 am »
Like Whammoed stated... if you can play it blind... then it could be 1 of two things... (not withstanding connector issues of course)
1. Bad RGB/SYNC drive circuitry on the CPU board
2. Monitor failure
It would be nice if you had a known good monitor to eliminate the CPU PCB as a problem
Most likely (if original components) ... you have an Electrohome G07 monitor... they are very easy to repair... Bob Roberts sells rebuild kits for them.
If you can't play it blind then it could be anything within the game psu/logic board/system... let me know if you can't play it blind... or if you rule out the monitor.
« Last Edit: March 26, 2008, 01:11:06 pm by RetroACTIVE »
Happy Gaming!
fixedpigs
« Reply #3 on: March 26, 2008, 01:07:11 pm »
i would assume it doesn't since the normal start up buzz sound isn't present...i'll try it out today though and let you both know what i find out...
thanks...!
RetroACTIVE
  • Gramps
« Reply #4 on: March 26, 2008, 01:09:52 pm »
Oh yeah... Check your fuses on your power supply... make sure your boards are getting proper power... may not be the monitor after all.
Happy Gaming!
fixedpigs
« Reply #5 on: March 26, 2008, 08:06:24 pm »
alright...so it definitely does not play blind...so that should absolutely rule out the monitor right...?
i took a peek inside and there are two red leds on the pcb on the right side of the cab that are lit up...
the led number readout on the rear mounted pcb that normally says '0'(or '8'...i can't remember) is not lit...
i wasn't able to get a good look at the fuses...does each pcb have its own set of fuses...?
thanks again for the help...!
D_Zoot
  • Last login:November 18, 2010, 03:59:37 pm
  • Sorry if I get any spit on you...
« Reply #6 on: March 26, 2008, 09:18:19 pm »
On the power supply board (lowest board in the cab) there should be three LED's lit.  If there is only 2 part of your power supply is dead.
I'm betting the +5vdc has gone out on you.
It is very common for these power supplies to burn up connectors.  I'd look at the connections first and check the header pins for cold/cracked solder joints.
Good luck!
D
RetroACTIVE
  • Gramps
« Reply #7 on: March 26, 2008, 09:51:51 pm »
Check all your power supply lines.... if your board system is original... it uses 4116 ram... which uses funky -5 and -12 voltages... common for -12 to pop on these old supplies.
Happy Gaming!
fixedpigs
« Reply #8 on: March 26, 2008, 09:54:32 pm »
since i plan on having this game for a while...would it be wise to look into getting this or this...?
RetroACTIVE
  • Gramps
« Reply #9 on: March 26, 2008, 09:57:09 pm »
I believe quanlee purchased the second one you reference and it worked out for him... but unfortunately he had other issues... the nice thing about that one is that it also has 4164 RAM upgrade...
see http://forum.arcadecontrols.com/index.php?topic=77497.0
Happy Gaming!
RetroACTIVE
  • Gramps
« Reply #10 on: March 26, 2008, 10:05:44 pm »
If it were me I would probably get mine through Bob Roberts... as long as the existing wiring harness is solid... since his connects into the original harness and does not piggyback on top of whats already there... I think its a bit cleaner... plus the power supply does not have a fan...
Happy Gaming!
fixedpigs
Re: joust power supply problems...?
« Reply #11 on: March 27, 2008, 11:17:55 pm »
so i pulled out the cabinet and looked inside...
led '1' was the led that was unlit...
so i looked at the fuses...f5 was burned out...!
there was an envelope inside of the coin bucket that contained extra fuses...what luck...!
so i replaced the f5 fuse with an exact match...
the startup buzz sound was kind of there & the monitor did the flicker white thing again...although now the coin door lights & p1/p2 lights did not light up...
and now led '1' & led '3' are not lit up on the one pcb...
i looked at the wire connections and everything looked ok...
the replacement f5 fuse is still intact at this point...along with all fuses...
would it be appropriate to guess that something went out on the power supply that caused the fuse to blow...and now whatever is out on the power supply is dead for good...so it can't blow the fuse again...?
i'm baffled as to why led '3' isn't on now as well...since all fuses are good...
i most certainly appreciate the help...!
RetroACTIVE
  • Gramps
« Reply #12 on: March 28, 2008, 08:45:26 am »
well... you could have very well lost the 5v voltage regulator... caused an overload which blew the fuse... and now is not functioning...
You should use the multi-meter to check all your supply voltages regardless...
Check the input to IC2 (723 voltage regulator) p12... should be rectified 24VDC and the output p3 (5.1VDC... which is obviously not there)
I suspect its either the 723 or the 2N6057 (high current transistor located on the heat sink)... bob sells re-build kits for these supplies... 9 times out of 10... they fix everything.
Happy Gaming!
RetroACTIVE
  • Gramps
Re: joust monitor/power supply no longer working...?
« Reply #13 on: March 28, 2008, 11:46:28 am »
oh... one more thing... if you have a short on your +5v rail.. which theoretically could have popped your voltage regulator... it may still be there... I would suggest you measure impedance from +5 to ground before you fix / correct your power supply issues...
I'm not certain what the correct impedance is... I can get that number for you... so you can tell if you are in the ball park.  I can tell you it shouldn't be zero ohms for sure...  ;)
« Last Edit: March 28, 2008, 11:52:21 am by RetroACTIVE »
Happy Gaming!
fixedpigs
« Reply #14 on: March 28, 2008, 12:18:51 pm »
that would be great...
i need to get ahold of a multimeter...
i did find out that led '1' is for +5vdc and led '3' is for -5vdc...so the only led that is lit is for +12vdc...
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
« Reply #15 on: March 28, 2008, 12:34:22 pm »
By the way.
Measure that impedance that RetroACTIVE is talking about with the machine OFF.
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
RetroACTIVE
  • Gramps
« Reply #16 on: March 28, 2008, 01:12:44 pm »
By the way.
Sorry for leaving that bit out, thanks Lutus! ... which makes me think a little further here...
You'll want to isolate it as much a possible... Disconnect each connector from each of your pcbs (CPU, sound and ROM including the 40pin ribbon).... then measure between +5 and ground on the CPU and ROM boards separately.  The sound board uses +12 and -12 to generate its own supply... don't worry about it (super duper unlikely that its the culprit).
Last Edit:
Also ... just noticed your previous post about -5....  measure between -5 and ground on the cpu as well...
« Last Edit: March 28, 2008, 01:15:15 pm by RetroACTIVE »
Happy Gaming!
Lutus
« Reply #17 on: March 28, 2008, 02:11:32 pm »
Just trying to keep people from learning electronics the hard way!!!   :dizzy:
fixedpigs
Re: joust power supply no longer working...?
« Reply #18 on: April 01, 2008, 12:57:10 pm »
i'm planning on ordering the following from bob roberts...
> 1    Item DS168 Packet Of 60/40 Solder - $1.00
> 1    BSLYR Pale Yellow Snap Short $1.00
> 1    BSLBR Powder Blue Snap Short $1.00
> 1    Lock set keyed alike 641 (1)1 1/8" & (2) 7/8" - $7.00
> 1    Soldering Starter Kit - $12.50
> 1    Pocket Multitester (Digital) - $8.00
> 1    SafeBack Discharger Kit - $8.00
> 1    10 Lamps 47 Bayonet 6V - $1.50
> 1    18" Fluorescent lamps (tubes) - $3.00
> 1    Wms Fuse Kit - $3.00
> 1    Williams PS conversion kit with 15A PS - $45.00
anything else i should consider for my joust cabinet problems...?
thanks...!
Lutus
« Reply #19 on: April 01, 2008, 01:56:38 pm »
Did I miss something?
How did you determine it was the power supply?
fixedpigs
« Reply #20 on: April 02, 2008, 01:32:50 am »
i was thinking of getting the power supply kit as a general upgrade since i've read a lot of things that it's just a good idea...
 :dunno
RetroACTIVE
  • Gramps
« Reply #21 on: April 02, 2008, 08:17:59 am »
 :dunno
If it were me... I would invest in the 4164 RAM conversion + Lithium Ion battery conversion.  4164 runs a lot cooler and is more reliable than the factory 4116 RAMs.
Do check your boards for resistive faults before you connect power back up to it cause you may end up in the same boat again.  :cheers:
Happy Gaming!
fixedpigs
« Reply #22 on: April 02, 2008, 08:59:55 am »
it actually has the lithium ion conversion already...i had thought about the ram conversion...i think i'll do that too...is it just these two things...?
Wms 4116 to 4164 Ram Power Adaptor    $8.50
4164 Ram (Alt Mfrs 3764 - 4264 - 4864 - 8264 - 9064)    $1.00
i'd need twenty-four of the ram chips right...?
definitely...hence the multimeter on order too... :cheers:
« Last Edit: April 02, 2008, 09:12:21 am by fixedpigs »
RetroACTIVE
  • Gramps
« Reply #23 on: April 02, 2008, 09:03:48 am »
You got it...
Happy Gaming!
fixedpigs
« Reply #24 on: April 02, 2008, 09:12:28 am »
or should i just try to rebuild the original power supply using this...?
Wms Def/Star/Bub/Rob/Jou OEM PS REPAIR Kit    $10.00
can't use the new ram with the original power supply though right...?
RetroACTIVE
  • Gramps
« Reply #25 on: April 02, 2008, 09:27:17 am »
You could do the rebuild (if you indeed have a psu problem)... the only thing is the rebuild kit is missing the big honkin' 20V 18000 uF cap the psu uses as its primary filter cap... which is a pretty important part of the whole package.  Bob sells replacements (they are snap in, not axial...) so you have to be creative about mounting it.  Personally I prefer original equipment whenever practical, however putting in a switcher is quick... so depending upon your time/patience with soldering... its up to you.
New RAMs work fine with old and new power supply... they actually use less power and don't rely on -5 and -12.
« Last Edit: April 02, 2008, 09:35:44 am by RetroACTIVE »
Happy Gaming!
fixedpigs
« Reply #26 on: April 10, 2008, 11:18:38 pm »
ok...
so i got my stuff from bob roberts today...sadly...no moonpies...
i got my multimeter and am excited to use it properly...what exactly should i be checking out...?
also...i should have it set to ohms to measure the resistance right...?
but what range should i have it set to...?
here are some photos of the power supply stuff...
fixedpigs
« Reply #27 on: April 10, 2008, 11:21:39 pm »
some more photos...
also...i powered it up today and the led 3 is lit up again...but the coin door lights and p1/p2 buttons aren't lit up like they were before when led 2 & 3 were on...what do you guys suppose that means...?
thanks again for the help on this...i really want to get joust going again...!
fixedpigs
« Reply #28 on: April 10, 2008, 11:24:03 pm »
the last three...of the main board and such...
please feel free to circle what i should be checking out with my multimeter in the photos...that would help me out a lot...!
thanks again...!
RetroACTIVE
  • Gramps
« Reply #29 on: April 11, 2008, 12:00:34 pm »
Unplug all your boards... measure resistance between ground and each pin that is supplied voltage by the power supply.
See if you have low resistive shorts... record the readings... I will check them against a known good to see if you have a fault.
Edit: Circled the power connectors and added pin out diagrams
BTW... what did you end up getting from Bob?
« Last Edit: April 11, 2008, 12:16:54 pm by RetroACTIVE »
Happy Gaming!
fixedpigs
« Reply #30 on: April 11, 2008, 08:29:51 pm »
alright...so for the first set...i got the following...
-5vdc = 1600 on the 2000k setting...
+12(ur) = i could never find a reading...
+5vdc = 225
+12vdc = 600 or 700
and on the second set...
+5 = 400 on the 2000 setting...
and here's a list of everything i ended up getting from bob...
> 1    Cable Clamp Pan head screws ½" (100) Black $2.50
> 1    Cable Clamp Assortment Bag of 25 Each Size (100 Total) - $7.00
> 1    Wms 4116 to 4164 Ram Power Adaptor - $8.50
> 24  4164 Ram - $24.00
RetroACTIVE
  • Gramps
« Reply #31 on: April 11, 2008, 09:09:28 pm »
+5vdc = 225
+12vdc = 600 or 700
Those look ok... not too far off from what I have...
Hook everything back up then measure voltage with power on directly on the connector(s)... set your multimeter for DC volts... I'm guessing its not auto-ranging so set your meter to the proper range to be able to see between 0 and say 25 volts... (not sure what your settings are on your meter)
Record your values...
Happy Gaming!
fixedpigs
« Reply #32 on: April 12, 2008, 07:47:44 am »
this is the multimeter i'm using...
http://www.therealbobroberts.net/meterdigit.jpg
after i power on the cabinet...where exactly do i put the probes to get a reading...?
do i just kind of jam them into the harness...or...?
RetroACTIVE
  • Gramps
« Reply #33 on: April 12, 2008, 09:04:42 am »
Set your meter DCV to 20V and take readings at the connectors of each of the CPU and ROM boards.
Yes take advantage of the fact that some metal is exposed on those IDC connectors. Careful not to "jam" too hard.. you should be able to get to the metal contact fairly easily.
Happy Gaming!
fixedpigs
« Reply #34 on: April 13, 2008, 12:05:36 am »
+5vdc = 225
+12vdc = 600 or 700
here are the voltage readings...
-5vdc = -4.84
+12(ur) = 12.78
+5vdc = .39
+12vdc = 12.18
+5 = .39
so...that +5 certainly looks suspect eh...?
i went ahead and took voltage readings from the other connections on the (power supply?)board with the three diagnostic leds too...
the top-most run of pins go(from left to right)...
-4.84
12.18
-14.3
12.3
12.3
.39
.39
.39
.39
then the bottom left set of pins(from left to right)...
35(200 scale)
12.81
12.21
12.35
.39
.39
and thirdly...the bottom right set of pins coming from the transformer(from left to right)...
no reading...
no reading...
-4.91
-4.91
12.28
12.2
no reading...
no reading...
and lastly...the transformer itself...from left to right...
12
12
no reading...
no reading...
no reading...
no reading...
so now what...?
thanks again...!
fixedpigs
« Reply #35 on: April 13, 2008, 12:14:58 am »
oh...and one more thing...
when i wiggled the harness connecting the transformer and the power supply...the coin door and p1/p2 button lights lit up...more wiggling made the led 3 go off...but the coin door lights stayed lit...more wiggling made led 3 come back on...and then everything seemed like it had a more solid connection...
RetroACTIVE
  • Gramps
« Reply #36 on: April 13, 2008, 10:56:17 pm »
Yeah... +5 is dead... and those readings from the connector of the transformer... those are AC voltages so your reading is going to be bogus w/meter set to DC.
Also those 15 pin molex connectors on the power supply board are known to go bad...(as mentioned earlier the burn up over time)
I'd go ahead and install your switcher.... see if the board comes back...
Happy Gaming!
fixedpigs
« Reply #37 on: April 13, 2008, 11:33:09 pm »
i'll do that tomorrow...wish me luck...!
and i didn't think about the dc...heh...
thank you once again for your help with this...i'm learning stuff i never would have known about otherwise...!
fixedpigs
« Reply #38 on: April 15, 2008, 08:32:25 pm »
victory...!
i put the new power supply in and hit the switch...success...!
it's so nice to play joust again... :cheers:
so here's my next question...
is it fairly simple and straightforward to upgrade the ram with the new ones...?
do they just pull out with bare fingers...?
once that is done...the new power supply harness just goes inline between the old one and the pcb right...?
thanks again for all of the help... :applaud:
RetroACTIVE
  • Gramps
« Reply #39 on: April 15, 2008, 09:36:04 pm »
victory...!
Removing RAM chips are simple... becareful with bare hands... many a newbie end up with a chip stuck in their thumb  :censored: OUCH! after this manuever.   I would use a small flat head screwdriver... wedge it underneath the chip and twist untl it comes up... working your way to the other end of the chip until its free...
I believe the adapter that Bob sells goes between the power supply connector of the CPU board and the CPU board connector.
Glad things are working for you!  :cheers:
EDIT: Note about ESD
Oh... along the "bare hands" line make sure you discharge yourself (touch earth ground ... somewhere) before you touch your board components.... its better if you have a ground strap or some ESD protection... but discharging yourself is sufficient... as long as you arent running around with wool socks on a carpet  :laugh:
« Last Edit: April 15, 2008, 09:53:38 pm by RetroACTIVE »
Happy Gaming!
