Main > Everything Else
Car totalled... YES!!
paigeoliver:
You should double check the year and model you are buying but I believe that Hondas normally have an interference design.
--- Quote from: shardian on March 25, 2008, 04:30:19 pm ---
--- Quote from: JMB on March 25, 2008, 04:19:23 pm ---If you are looking at Civic's with 100k+ find out if the timing belt has been changed or not.
Good question.
Does anyone know if Civics have interference or non-interference valve design?
paigeoliver:
Ok, looked it up, all Honda and Acura engines are interference design with the exception of the 3.2 V6 found in some Acura SLX and Honda Passports.
Technically that is a $1000 strike against a honda right there. Gotta change that timing belt a couple times in the service life of a used one.
HaRuMaN:
I think PO works for Ford or is a stockholder or something... ;)
shardian:
--- Quote from: HarumaN on March 26, 2008, 07:29:08 am ---I think PO works for Ford or is a stockholder or something... ;)
Paige has, shall we say, eclectic tastes. Have you seen his apartment, or all of his former vehicles?
HaRuMaN:
Yes, I have... ::)
Although I must say his current vehicle is a step in the right direction...
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
