Main > Main Forum
Adding LED's to coin return buttons
Pages: << < (5/7) > >>
TazMan:
--- Quote from: crashdmj on May 28, 2003, 02:10:37 am ---How do you think the red wedge offered by happs would look for the red coin return button's? I mean would it lite it up enough you think?
Derek
I don't know for certain; but, I had asked my rep at Happ's for the specs on their LEDs and she didn't have any.  I would guess since they list them as replacement for the illuminated push buttons they may not work that great for the coin door.  I know I have a Happ door and added the 4 bulb wedge base leds (from SuperBrightLeds) to each coin return button and that did the trick nicely.  I took some pix of them tonight - but I left my card reader at the office - so I'll post em tomorrow.
<Edit> Here's the pic.  Keep in mind these are the default yellow plastic coin return buttons from Happ.  But with the green 4 bulb led, it helps keep my green theme goin'
Justin:
Well, I don't know about you guys, but my 1983 Centipede coin door does not use wedge base bulbs.   These are cylindrical base, twist-in bulbs.
I was thinking of using the original incandescent bulbs, and somehow wire them through a transformer.
The bulbs seem to read: 6.3 V  0.25 A    does this sound right?
TazMan:
Justin,
Are you talking about bayonet style bulbs?
If so, SuperBright carries those also in 6v or 12v.
<Click Here>
Justin:
yes, these are the ones!  Thanks, I will consider these.
crashdmj:
Ok I need help Tazman, which lights do I buy from that SuperBrightLeds? It runs off the 5V from a PC powersupply so do I need anything special to do that?
derek
Go to full version
