Main > Main Forum
How do I change directions the mouse goes?
IceCold:
--- Quote from: u_rebelscum on May 24, 2003, 07:27:00 am ---
--- Quote from: IceCold on May 23, 2003, 08:35:46 pm ---Now that I think about it(yes, I can think) I'll just wire the vertical optics electrically to where the horizontal optics are. Then I won't have to do any mounting or anything, just solder a few wires.
Yes, you can do is. Quick and easy hardware solution.
Analog+ can reassign mouse's axis, so you could assign mouse Y axis to the game's player 1 X axis, but it would only work in Analog+.
A very few mouse drivers can reassign the mouse axes for windows, which should also effect mame. I don't which drivers, though.
If I was you, I'd go with the hardware fix. If I was me (hey, I am me :P ), I'd do the Analog+ way. ;D
I tried the hardware fix and accidentally melted my mouse wheel thing :( , so I had to superglue a new one on, and now it's not perfectly level, and the spinner doesn't work as well >:( .
I probably should try the hardware solution again, and just make sure my wheel is nowhere near it.
