Main > Main Forum
setup for marble madness
Pages: << < (2/2)
DeLuSioNal29:
Can you provide some more detail?  Perhaps what brand trackball you are using and what version of MAME you are using.  CPU speed would help too.
That way if other users have similar setups then can tell you what theirs is set to.
~  DeLuSioNaL
stan2323:
--- Quote from: DeLuSioNal29 on March 16, 2008, 11:11:52 pm ---Can you provide some more detail?  Perhaps what brand trackball you are using and what version of MAME you are using.  CPU speed would help too.
~  DeLuSioNaL
Another part of the problem.  I do not know what info you need to make a recomendation.  I thought that the #s would be the same for each game and would not depend on the computer.
I have a HAPP 3 in trackball hooked up USB to a hud that has 2 GP-WIZ MAX 32 also hooked up.  It is a Gateway Laptop.  The processor is an AMD Athlon 64 at 2.93 GHz with 1 GB RAM.  Windows XP Home using EasyMame 5.6.6 as the front end, and Mame 0.123.
ids:
--- Quote from: stan2323 on March 17, 2008, 09:04:57 am ---[I do not know what info you need to make a recomendation.
They key would be the type of trackball, how it's connected (direct usb/ps2, through an optical encoder, etc)....
I tried to get a collection of this type of data going: http://forum.arcadecontrols.com/index.php?topic=77375.0
but nobody was interested :cry:
u_rebelscum:
--- Quote from: stan2323 on March 16, 2008, 09:36:55 pm ---I am trying to set up Marble Madness with the track ball.  What is values that should go in for the list below.   I have tried all kind of mouse X, mouse X+, mouse X-, mouse Y, mouse Y+ and mouse Y- but the marble moves slow even when I spin the track ball fast.  If I use the defaults joystick settings it goes very fast.
First off, I crossed off the stuff you should not see in your input mapping for MM.  Map as follows:
Track X Analog    Mouse X
Track X Dec --- (aka: NO mouse anything)
Track X Inc ---
Track Y Analog    Mouse Y
Track Y Dec ---
Track Y Inc ---
The -Dec and -Inc lines are for non-analog inputs (like your keyboard).  If you map your mouse to these, mame will treat the mouse as a digital input and suck.
Then worry about the sensitivity mentioned in prior posts.
stan2323:
--- Quote from: u_rebelscum on March 17, 2008, 03:33:12 pm ---
Track X Inc ---
Track Y Dec ---
Track Y Inc ---
Thanks.  That fixed it.  Once I got rid of the DEC and INC it works the way it should.  I did try changing the sensitivity again and I can tell the difference, much better.  Thanks
Pages: << < (2/2)
Go to full version
