Author Topic: LCD Topgun + ? = Vista 64?  (Read 1014 times)
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
« on: March 11, 2008, 04:06:50 pm »
Do you guys know of a driver that'll work with the LCD TopGun in Vista 64?  I want to take my rig to the next level, but if I lose gun functionality, I may have to dual boot.
Jakobud
  • Last login:May 05, 2024, 10:53:37 am
Re: LCD Topgun + ? = Vista 64?
« Reply #1 on: March 11, 2008, 04:56:57 pm »
1. Why are you using a 64-bit OS for Mame?  Are you seriously expecting a performance boost?
2. Why are you using Vista?  If a performance boost is what you are looking for (I assume from question #1), then you do NOT want to be using Vista...
TOK
  • Last login:January 24, 2024, 05:14:24 pm
  • The Game Always Wins
« Reply #2 on: March 11, 2008, 05:00:14 pm »
He didn't say he wanted to take it to the next BETTER level.  ;)
Seriously, that kind of stuff won't help MAME. Get a copy of XP and strip as many of the unnecessary Services out of it that you can, either manually or using a gaming app.
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« Reply #3 on: March 11, 2008, 05:15:11 pm »
I use vista 64 bit, I can run all chd's but 1 with vista 64 & mame 64.  Xp 64 is not going to be supported by arcadevga per andy.  As of right now no there are no gun drives for vista.  We will have to wait.
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
lanman31337
« Reply #4 on: March 11, 2008, 06:25:14 pm »
1. Why are you using a 64-bit OS for Mame?  Are you seriously expecting a performance boost? Yes I am actually, with most of the CHD's I should see a boost, as well as some of the CHD's were run on 64 bit processors.  And with running a 64 bit OS, I should see some improvement.
2. Why are you using Vista?  If a performance boost is what you are looking for (I assume from question #1), then you do NOT want to be using Vista... Stripped down, Vista isn't all that bad.  If I get rid of most of the bloatware I don't need, I'll be golden.
This is why I want to do such animal - http://www.mameworld.info/ubbthreads/showflat.php?Cat=&Number=145164&page=0&view=collapsed&sb=5&o=&fpart=1&vc=1&new=1204679197#Post145163
divemaster127
« Reply #5 on: March 11, 2008, 07:03:42 pm »
Gauntlet Legends is the only game  I have issues with I need about 15% percent more on my cpu
lanman31337
« Reply #6 on: March 11, 2008, 08:10:16 pm »
Taz-nz did benchmarks and he's running pretty good on a 64 bit build of mame than the 32 with vista.  Anyways, that's another story, divemaster thanks for the info.  I checked on the topgun site and, well, their support is unique to say the least  :dizzy:
taz-nz
  • Last login:June 12, 2019, 10:12:13 am
  • If all else fails burn the manual!
« Reply #7 on: March 12, 2008, 03:40:26 am »
 :banghead: :banghead: :banghead: :banghead:
Not to put words in Lanman's mouth but:
1) Because he wants the average 20%+ preformance gain that comes form running MAME 64bit on a 64bit OS. Aaron , John IV, myself and a few others have all post benchmarks that show MAME is noticable faster in 64bit.  Anyone with a Athlon64 X2 or Core 2 Duo should expect to see a preformance jump when switching to a 64bit OS.
2) Why Vista you ask: (I'll quote myself on this one to save time)
- It cheaper: you can buy Vista Home Premium 64bit cheaper than you can Windows XP Pro 64bit. (Of course there are pirate copies of both available)
- It easier to get: alot of places will look at you blankly if you ask for XP Pro 64bit, Vista 64bit is easily found in almost all computer outlets.
- Drivers: this is the big one, Vista 64bit has good driver support for most system harware, and average driver support for periphals. both will only improve with time, XP 64bit on the other hand was basically still born and as such has only average driver support for system harware, and rubbish support for periphals.
- General Support:  Vista is new and while most people don't like it support for it will only increase over time, XP 64bit is very little support and that will only get worse with time.
The only problem I've seen to date with running Vista 64bit in a MAME cabinet is avialablity of lightgun drivers, but this is more of a 64bit OS problem than just a Vista problem.
The main complains about Vista are:
- The endless warning messages, easy fixed turn UAC off.
- It's slow, again easy fixed, only install it on a system with 2GB of RAM and either a Athlon64 X2 or Core 2 Duo. (Find it's very quick actually)
- It bloated, (can't count the number of times I've heard that about XP over the years),Simple, strip it to the bone with vLite.
- Incompatiblity, who cares MAME 64bit works purfectly, most of incompatible software and hardware is irrelavant to MAME users anyway.
Simple fact is most of the people who complaining about Vista would be lucky if they've played with it for more than 5 mins in a department store.
What can i say to that other than your wrong, MAME 64 running on Vista 64bit will always beat MAME 32 on even most optimised install of XP.
It really shocks me that two members of this forum who have posted here more often than me by a factor twenty each, have not managed to pick up on the fact the MAME 64 on a 64bit OS is faster than MAME 32. Hell my benchmark thread alone is fast appoaching the 10,000 views mark, I'm surprised with those kind of numbers that everyone on this board hasn't read it atleast twice by now.
« Last Edit: March 12, 2008, 04:12:06 am by taz-nz »
TOK
« Reply #8 on: March 12, 2008, 12:09:03 pm »
Thanks for the correction... Maybe I'll upgrade to see if I can get Donkey Kong from 40,000 FPS to 75,000. Not having any frame rate or driver issues on the XP setup I'm running is why I haven't read your thread.
