Main > Reviews
GGG micro-leaf switches
RandyT:
--- Quote from: Zobeid on March 27, 2008, 11:42:53 pm ---How is that a problem? I don't imagine the cardboard casting much more shadow than the spring itself did.
I suppose the most ideal answer would be a spacer made of some transparent material. Plastic tubing?
I think something like these would get you there without causing a shadowing issue. They could even be stacked, if one found it necessary to do so.
RandyT
Jdurg:
How good do these things work on joysticks? I don't mind the clicking of the microswitches when buttons are pressed, but on the joysticks it may get to me after a while. Do this things stand up to the test of time on joysticks, and do they also fit standards Happ Competition Joysticks and Ms. Pac-Man style four-ways?
RandyT:
--- Quote from: Jdurg on April 05, 2008, 12:07:24 am ---How good do these things work on joysticks? I don't mind the clicking of the microswitches when buttons are pressed, but on the joysticks it may get to me after a while. Do this things stand up to the test of time on joysticks, and do they also fit standards Happ Competition Joysticks and Ms. Pac-Man style four-ways?
They are specifically designed to interact with one of the actuating / plunger retaining prongs on a pushbutton. A drastically different design would be required to adapt them to a joystick.
RandyT
Jdurg:
Thanks. Saved me about $30 there. ;D
Ummon:
--- Quote from: RandyT on April 05, 2008, 12:43:56 am ---
RandyT
Are you still contemplating doing a stick design for them?
Navigation
[0] Message Index
[*] Previous page
Go to full version
