Main > Everything Else
Recommended wireless print server?
<< < (3/4) > >>
2600:
--- Quote from: csa3d on March 17, 2008, 09:30:58 am ---
Fios puts the digital TV's and recorders on the same IP range as linksys defaults it's routers to.  In order to get the print server to work, you have to point it to the sub 100 range, and to do that, you need to first be able to access the admin panel, which you cannot do unless you have a spare router to access it directly through connection.
Or you could of used a crossover cable.
ChadTower:
--- Quote from: csa3d on March 17, 2008, 09:30:58 am ---Fios puts the digital TV's and recorders on the same IP range as linksys defaults it's routers to.
Interesting.  Are the DVRs behind your router, then, or in a DMZ?
There is no danger of me getting Fios any time soon - I can't even get DSL.  Plus I have DirecTV.   :)
2600:
--- Quote from: ChadTower on March 17, 2008, 09:43:16 am ---
The way my FIOS is setup is:
Router is connected to the "control box" via Ethernet.
The router then routes the traffic to COAX (for Set top boxes), Wireless, and Ethernet.  Each of those subnetworks is independent and can be controlled independently of each other.  There are actually a surprising number of configurations compared to your normal home use routers.
ChadTower:
That must be their router then, yes, since it has coax on it?
2600:
--- Quote from: ChadTower on March 17, 2008, 10:00:37 am ---
Yes, I forget the manufacturer offhand, but I can find it if you are interested.  Big SOB, but they have a newer model out that is much smaller.  I don't have the newer model, but the older model has much better wireless coverage then my WRT54G and I thought the WRT54G was pretty good.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
