Main > Everything Else
how to remove car stereo????
<< < (5/6) > >>
danny_galaga:
--- Quote from: ChadTower on March 08, 2008, 11:04:50 am ---
No one around here steals stereos anymore.  Too hard to get out, not worth enough.  They go after GPS systems and airbags.  GPS systems are worth 3x as much and airbags 20x.
i read an article in the paper a little while back of a sad trend- stealing dashboards! the thieves get in there with cordless jigsaws etc and chop out the whole dash, leaving you with essentially a write off. they do it that way for the things like gps etc, which they can remove from the remains of your dash at their leisure...
cant find any links right now but in the paper was a picture of one of the cars hit. only good for the wreckers.
Havok:
Bah, professional installation...
Just go Hulkamania gone wild on it!!!
Singapura:
--- Quote from: paigeoliver on March 08, 2008, 11:39:31 pm ---Also, you might want to do a reality check, as it is highly likely that the NEW stereo you have is inferior to the one already installed.
Did you read correctly? His current stereo is a BOSE, acronym for buy other stereo equipment. This is the same company that sued it's customers for having a bad opinion about them. http://caselaw.lp.findlaw.com/scripts/getcase.pl?court=US&vol=466&invol=485
paigeoliver:
I am not an expert, I just said do a reality check and make sure the new equipment is actually better than the old that is all. In a lot of cases that new "nice" car stereo won't be as good as the factory unit in higher end car.
--- Quote from: Singapura on March 12, 2008, 01:32:46 am ---
Samstag:
--- Quote from: billf on March 09, 2008, 12:11:51 am ---
--- Quote from: Tiger-Heli on March 08, 2008, 12:29:34 pm ---You don't need to replace the amps or speakers.
You need this wiring harness, this integration adapter, this antenna adapter, this dash kit, and these instructions.
Wow, including shipping those items come out to $97.94.  Might be a good idea to see what a local pro installer quotes and then decide from there.
A local pro will add a markup to those parts unless you provide them.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
