Main > Main Forum
Jamma + MAME? possible?
paigeoliver:
Unplug Golden Tee board, unplug power supply, plug in J-Pac.
You have to unplug the power supply to keep it from ruining itself by running with no load (the J-Pac does not use it).
SirPoonga:
--- Quote from: paigeoliver on May 22, 2003, 01:32:30 am ---Unplug Golden Tee board, unplug power supply, plug in J-Pac.
It's not that simple.
What about video and sound? Those are handled in JAMMA, but the JPAC just does controls, and basic video which requires a specific setup.
paigeoliver:
I was only answering what needed to be done to switch once he set everything up.
Generic Eric:
Isn't there some multi jamma interface that this fella can use? I thought there was. It wouldn't be from ultimarc though.
paigeoliver:
Clay Cowgill sells a Multijamma kit at multigame.com
Not sure if that would work at not, if it keeps the Golden Tee running in the background then it would work, otherwise it wouldn't because the power supply would conk out from running with no load.
