May 09, 2024, 07:50:46 am
how would you go about doing this and what makes it a hack and not just soldering.
I would like to know how to do one.
Thanks I'll be counting on you
Using an exacto knife will do the job. Just don't be too rough, you want to leave the coper on the pad.
Wow thanks you were a lot of help...anyway do I still need an I-pac for this? Also could tin wire work?
Just wanted to add my £0.02 here. Dreamcast hacks can be a bit dodgy. Before you dream about plugin a dreamcast hack into the console you should check each connection with a multimeter! The dreamcasts I/O board is really sensitive and will blow its F1 resistor if you've got a dodgy connection. Lots of info on the net for this. Its speculated that sega originally did this to slim the number of 3rd party controllers. Anyway I blew one on my original dreamcasts when I did my very first hack. Be aware as well if your doing an analogue and digital dreamcast hack you need to use a 4 pole switch to dont connect all of them at the same time. Hope that helps.
Great now I have to go out and buy a fricking multimeter soooo much money!!!!
Quote from: LoyalistRevolt on March 06, 2008, 07:04:28 amGreat now I have to go out and buy a fricking multimeter soooo much money!!!! Who said anything about building arcade controls costing you nothing. Get used to spending money or find something else to do.Best Regards,Julian (Fozzy The Bear)
Quote from: Fozzy The Bear on March 06, 2008, 08:41:39 amQuote from: LoyalistRevolt on March 06, 2008, 07:04:28 amGreat now I have to go out and buy a fricking multimeter soooo much money!!!! Who said anything about building arcade controls costing you nothing. Get used to spending money or find something else to do.Best Regards,Julian (Fozzy The Bear) Wow what was that all about?
I mean duhh hobbies set you pack a pretty penny , for my game collecting I have spent near 1250$, just where did all that anger come from.....
Hey can you do a pictoral guide on wiring controls to an Xbox 360 controller. I want my cabinet to have the capability to hook to a 360 easily.
Also I'm Fozzy The Bear I'm sorry If I irritated you, you really helped me a lot, you deserve to be worshiped.....
